Forum Moderators: Lobo3433 Forum Coordinators: bwsupport
Blender F.A.Q (Last Updated: 2025 Feb 23 7:55 pm)
Hi SilentWinter Just opened up 2.81 had downloaded and had not played with it yet but looks like one the polygroup option is missing from 2.81 and is still visible as an option in 2.8 so not sure if that is a bug that needs reporting or if a setting needs to be changed so at this moment do not have a clear answer to your question
Lobo3433
Thanks, but that's just the vertex order, not vertex groups (vertex order was there before and is important when making morphs).
The thing I'm looking for was called 'polygroups' and allowed DS to import an obj with vertex groups assigned (such as head, neck, etc) and then use the figure setup tool. I could do it with geometry editor in DS but it's much faster and easier in Blender.
Sorry was trying to edit my previous post when I saw I made an oops and saved it with the wrong answer
Lobo3433
No worries, cheers.
At least it's confirmed not just me :lol:
I'll look at the settings later when I get the chance and bug report it if it can't be found.
Thanks
I am looking thru setting and everything I can think of and that check box is missing but is visible in 2.8
Lobo3433
Yeah, it's in 2.8 ok. 2.81 moved the export dialog to a new window and this is missing from it.
I will keep looking into it since I am sure this will come up more figuring it is a bug
Lobo3433
Cheers.
Interestingly, when importing an obj, clicking "keep vertex order" allows you to select 'polygroups' - just not at export. Sounds like an oversight in that case. Luckily I've still got 2.8 as an install - but 2.81 does seem like an improvement in most ways.
I noticed that also on import it is there but not on export I am still getting use to 2.8 got 2.81 just to have and begin looking into some of the improvements but beyond opening it have not done much with it yet just noticed your FB in your signature sent you a friend request
Lobo3433
SilentWinter/Lobo :
Yeah, it looks like it is an oversight/possible bug -- It is still listed as a flag in B2.81 Python API, so the boolean toggle can still be used, but is not exposed.
OBJ Polygroups flag : use_vertex_groups (boolean, (optional)) – Polygroups
So, for my custom export scripts where I have the flag enabled, it should work (all automated - not user selected). I just downloaded 2.81, and will look at the OBJ export code for confirmation - will report back later...
I need it for my work with Daz Studio as well, so you had me worried for a moment -- You just need it exposed on your end for usage.
As a work-around for now if you want to work in 2.81, complete your work in 2.81, open up 2.80, select and copy your figure in 2.81, paste your figure into 2.80, and then export as usual. It's faster than the writing seems - I do this with 2.80 and 2.79 where my custom scripts reside until I get around to upgrading the code to 2.8x structuring. I usually have them both open at same time.
Okay, I'm back after testing, and fixing the export script for my use.
Sharing is caring - so, if you don't want to wait for a release fix, here is the fixed OBJ export panel : Fixed OBJ Export to include Polygroups
I tested with a V4 figure, but only reading exported OBJ code (no Daz Studio import) - Polygroups included correctly in OBJ file...
Thank you Daremok3 appreciate the tip and script
Lobo3433
DaremoK3 posted at 2:29PM Wed, 27 November 2019 - #4371177
- Instructions included for manual install (not set up for ZIP install within addons preferences panel - though may work, but simple manual install - look at instructions text file)
Awesome - thanks
Lobo3433 posted at 2:30PM Wed, 27 November 2019 - #4371070
I didn't get a request -- not sure if pages like that have 'friends' - can you double check?
It shows I am following the page
Lobo3433
Ah, 'follow' is different from 'friend request'. Are you down as Lobo? I'll check it later (no time now). Cheers
I did not realize it was a page so no friend request option but my forum signature has my FB link to my actual profile anyone from this forum is free to sent me a friend request Happy Thanksgiving everyone
Lobo3433
So I've just installed 2.81 and it's great ... except when I go to export an obj and get the new export window. On the surface it's an improved workflow, but there's an option missing: 'Polygroups' - this is what I'd check before so that it can import to Daz Studio's figure setup tool and create bones from the vertex groups.
Does anyone have any idea which options I'd need now to export as a single obj with vertex groups intact?
Cheers,
SW
Silent Winter's Facebook Page:
