Forum Moderators: nerd Forum Coordinators: Anim8dtoon
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Feb 18 8:01 am)
Although PoserPython is a separate Python implementation, it still needs to be maintained to remain compatible with industry specifications. The EPMD is a maintenance utility for developers and studios to improve Python based code and script integration.
The concept is similar to a self support application emphasizing compatibility. If a user has an issue that callback to a Python reference, the EPMD will execute any library or document without the user needing to locate the library.
There is a startup project WIP using Visual Studio for this in the works at Github. For more info, leave a message below.
Sooo.. does that mean if it were developed for poser, a user could run some of the older python library scripts from earlier poser python (2.6, 2.5) etc that will no longer work with 2.7? Or am I misunderstanding?
Consider me insane if you wish, but is your reality any better?
In lieu of Python 3.8 replacing EoL Python 2.7 and below, it becomes evident that a centralization approach is needed to maintain all existing and future end user based content. Thus, an Extension and Plugin Manager Developer kit ((EPMD) should be made available as a free download for all future content and PoserPython scripts.
To get the ball rolling, a private developer can be hired to create the application, yet encouragement from the Poser community will be needed to include it in future versions. Any comments? Please respond in this forum and post.
