Thu, Nov 28, 8:14 AM CST
Subject: What is the best way to save a morph so it can be easily clicked / added?
digitalmediaservices ( ) posted Thu, 28 November 2019 at 2:28 PM · edited Sun, 24 November 2024 at 3:03 PM
Say you have one figure that has a morph you like using in other figures, and you can do the typical transfer morphs from the one character to another using the menu. But how do you save that individual morph to where its accessible in your collections? That way you don't need that base figure in the scene at all. I see other morphs out there so I imagine it is possible, yet I can't seem to figure it out for some reason. I've read about how there is setting that needs to be changed just to export morphs yet that had no effect for me. Any help is appreciated thx.
Biscuits ( ) posted Thu, 28 November 2019 at 3:48 PM
I made a video tutorial about making and saving morphs.
Videotutorial
Hope this helps.
My 2D&3D Store
My Youtube Channel
Glitterati3D ( ) posted Thu, 28 November 2019 at 4:18 PM
Do you want to be able to inject this morph anytime or just load the figure with your morph already loaded and ready for use?
You can create an INJ file using Poser's File>Export>Morph Injection but first make certain you have Use Binary Morphs in the General>Miscellaneous settings turned on. You'll then be asked which folder in Poses where you want to save the morph INJection.
If you just want to be able to load the figure with your preferred morph, save the figure to a new CR2 and a new name in the character folder, by clicking on the + symbol at the bottom of the character folder and typing a new name.
digitalmediaservices ( ) posted Mon, 09 December 2019 at 1:10 AM
Biscuits posted at 2:08AM Mon, 09 December 2019 - #4371632
Videotutorial
Hope this helps.
Thanks, I liked your tutorial, especially the pacing, I didn't feel like you dragged me at 200 mph through it like I feel on many problems. That Z brush does look pretty cool.
digitalmediaservices ( ) posted Mon, 09 December 2019 at 1:13 AM
Glitterati3D posted at 2:10AM Mon, 09 December 2019 - #4371639
Unfortunately the problem remains. If it helps, the morph still works to be transferred from one figure to another while inside Poser using its function. But if I try to save the morph then just add it to a figure it loses its effect. Any ideas?
Glitterati3D ( ) posted Mon, 09 December 2019 at 9:32 AM · edited Mon, 09 December 2019 at 9:36 AM
digitalmediaservices posted at 10:30AM Mon, 09 December 2019 - #4372792
Did you create an INJ file so you can just inject your morph after exit and re-entry?
If you did and it's not loading automatically, all you have to do after injecting the morph is look on the parameters pallet and find your morph and then, dial it to 1.00
Unless you make some manual changes in the CR2, it won't load automatically unless you dial it in.
Here, I injected one of Fabiana's head morphs for La Femme
But it doesn't change the figure until I dial it in.
