Wed, Jan 8, 12:27 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
Carrara Free Stuff here.
Subject: Carrara's Anime Labs
William_Rivera ( ) posted Fri, 13 December 2019 at 9:23 AM · edited Wed, 08 January 2025 at 12:26 AM
Hello my name is William your host at anime labs. I will show you the potentials of anime in carrara. Did you know that Anime is a global hit? Watch and learn.
William_Rivera ( ) posted Fri, 13 December 2019 at 9:25 AM · edited Fri, 13 December 2019 at 9:25 AM
I'd like to share some skills I use to render anime characters, I flatten the character making it look 2D.  I use carrara but it might be possible in Daz studios.
Please see the images below for better understanding.
This image has been resized to fit in the page. Click to enlarge.
Using the scale X and Y can make possible the flatten of a character you can make her as flat as you want.
Ear Pulled, Square big eyes, small mouth, unrealistic skin and light bulbs on the cheek are all anime features.
Lets start with lightings
See images below please:
Ok the Bulb is at 35% lighting at the color on the radial is
H= 96.50%
L=60.53%
S=29.99%
This bulb gives proper anime skin lighting unrealistic notice that the bulb is over by the edge the character is centered
Now we go for the Distant light settings see image below please:
Ok the Distant light is at 80% lighting at the color on the radial is
H= 95.77%
L=78.94%
S=37.48%
The location of the distant light can be seen on image 1.  Both lights are set to best settings - raytraced under the effect tab
This conclude the lesson on the environmental light settings is more of a pinkish lights.
The following lesson will focus on the Ear Pulled a very important anime feature disregarded by many :P
We will place our lovely model facing forward for better teaching.
This model is Aiko 3 with kioki morph, This character has many morph and lots of clothes.  Aiko 3 is widely supported in the Japanese Community including pixiv.net  PoserClub.net.
In order to pull the ears on Aiko 3, see the images below:
The values are as follow
Earin= -2.0 (thats minus 2.0)
EarBig= 0.7
EarSmall= 0.9
I doubt you can do these with Aiko 4 or up.  I always recommened Aiko 3 for your anime needs.
Next Lesson we will talk about Triangular Chin
This next lesson focuses on her Triangular Chin.  The triangular chin cannot be done using Aiko 3 alone.  You need to have Kioki for Aiko 3 to make this triangular chin, without Kioki I do not think you can create such a perfected Anime Chin.  Kioki by Capces can be purchased here at Daz. at https://www.daz3d.com/kioki and Kioki Requires Aiko 3 morph and map located here https://www.daz3d.com/aiko-3-0-morphs-and-maps now on to the lesson.
The values are as follow:
JawH=0.3
JawSquare= 0.9
Here are the eyes lesson, possibly the hardest and tedious part is morphing these eyes in an anime style shape.  First you need to darken the eye socket materia, by making the eyes socket material dark it will create a dark outline all around the eyes. Again, the morph I used on these requires the Kioki Morph.  Here are the values of the Anime Eyes Shapes along with links.
I recommend Dumb or Anime Eyes for Victoria 3 (Victoria 3 Eyes fits on Aiko 3) @ https://web.archive.org/web/20060925192216/http://jjdelpy.free.fr/Poser/doaeyes.html
The values for the eyes are as follow:
EyesScale 0.5
EyeSpace 0.5
EyeAngle Up 0.2
EyeGumDrop 0.3
EyeinSquare 0.3
Eyelwrflat 0.3
EyeOutDwn 0.4
EyeShape1 0.8
EyeUpFlat 0.1
EyeDepth -0.1
EyeHeight 0.1
EyeWidth 0.1
Eyelidshllw 0.1
Eyelidshvy 0.1
Lasheslong 1.0
Lashlofull -9.0
Headshape and nose is as follow:
HDstylized 0.8
ThroatThin 1.0
Nosepointed 0.4
MouthSmall 0.2
MouthNarrow 0.2
Doing the HDStylized will automatically make the nose small and will also give the head an anime style.  This are the basics of making an anime head using Aiko 3 with Kioki morph in Daz Studios it may be possible to do all this but I am not 100% sure if Kioki will work in DazStudios, I assume it does because is sold here.  The above was all done in Carrara.
This next lesson we will focus on Anime Hair we will need the following for this tutorial
https://www.daz3d.com/xinxin-for-aiko-3
https://www.daz3d.com/dixie-hair
Rainbow for Dixie hair by fantasiesrealm
Elfdance enchanted hair expansion
We will turn this
to this
Until next time...
If you have any question on this lesson feel free to ask
Be sure to have these
Rainbow for Dixie hair by fantasiesrealm you need to go to Fantasy Realm Website to purchase this item google is your friend
Elfdance enchanted hair expansion probably need to contact Swam via renderosity sitemail to sell this items for you.
A) Load XinXin Hair in the hair category Daz Aiko 3Hair
View the Hair Shaders or texture for this hair
Double click the texture select DixieTrans6.jpg at littlefox texture folder Dixie hair and apply this alpha.
Consolidate the shaders
Under Color select the texture map
Select texture number 26 on the folder Rainbow Dixiehair and place it on the Color drop down
do the same for the bang and tails
Go to the prop category and select the elfdance hair
and apply it at the front of XinXin hair.
Drag and drop the shader for tail or bang and apply it on the Elfdance Bang
The Accessory needs the following colors basically purple
H=82
L=50
S=100
There is your Anime Hair !!
About the Cheek Lights and Skin will required some photoshop and some advance lighting in carrara.  I am not going to discuss these here if you are still interested in those send me a email wrr@3dcgx.com
William_Rivera ( ) posted Fri, 13 December 2019 at 9:49 AM · edited Fri, 13 December 2019 at 9:49 AM
Yoko Littnera
Yoko is made with Aiko 3.0 Rendered in Carrara
William_Rivera ( ) posted Fri, 13 December 2019 at 12:43 PM
MistyLaraCarrara ( ) posted Fri, 13 December 2019 at 1:16 PM
XinXin 💕
Thanks for this information 🐼
Steve K. ( ) posted Fri, 13 December 2019 at 3:19 PM
Very cool.
diomede ( ) posted Fri, 13 December 2019 at 4:38 PM
Agreed. Very cool. Creative way to get a cel look.
William_Rivera ( ) posted Sat, 14 December 2019 at 4:17 PM
Good morning anime scientist, a vigilante on the loose You will notice one uses Filter Forge the other is original.
William_Rivera ( ) posted Sun, 15 December 2019 at 5:24 PM
Sephiroth from final fantasy 7
William_Rivera ( ) posted Tue, 17 December 2019 at 8:06 AM
Have you all been at the Carrara cafe all sort of goodies there.
William_Rivera ( ) posted Thu, 19 December 2019 at 10:42 AM · edited Thu, 19 December 2019 at 10:46 AM
I placed my entry for the holiday contest and I'm asking for votes my link here link entry 32all done in carrara
William_Rivera ( ) posted Thu, 19 December 2019 at 11:14 AM · edited Thu, 19 December 2019 at 11:15 AM
thanks everyone in advance, have a merry christmas and happy new year.
please vote @ Entry 32 Click Here for Vote
William_Rivera ( ) posted Sat, 21 December 2019 at 8:39 PM · edited Sat, 21 December 2019 at 8:42 PM
There is a nice elevator set for Carrara, I will use this scene to make my next render set Elevator sharecg Carrara
William_Rivera ( ) posted Sat, 21 December 2019 at 8:48 PM
Cloud on the Garland Bike, scene Tim alley stonemason, character is Hiro 3 my works https://3dcgx.com
William_Rivera ( ) posted Sat, 21 December 2019 at 9:24 PM
Cloud, Tifa, Aerith and Yuffie on the Shinra building
William_Rivera ( ) posted Sun, 22 December 2019 at 5:09 PM · edited Sun, 22 December 2019 at 5:11 PM
Merry Christmas from me to you all and a happy new year !!!!
file_a5e00132373a7031000fd987a3c9f87b.jp
William_Rivera ( ) posted Mon, 23 December 2019 at 12:33 PM
I notice that things are a little bit less stricter at the gallery I remember back in 2008 when i place a simple nude image I was attacked by the moderators and have my pic removed. Now I see people placing nude pics like crazy without moderation, I stopped placing nude pics alltogether a while now.
William_Rivera ( ) posted Tue, 24 December 2019 at 6:54 PM · edited Tue, 24 December 2019 at 6:56 PM
e8ecac01aab5756c67eb1d15ee1f9480_origina Merry Christmas from https://3DcGX.com
William_Rivera ( ) posted Thu, 26 December 2019 at 12:08 PM
Our next anime Lesson consist in making money rendering....interesting subject isnt it?
William_Rivera ( ) posted Thu, 26 December 2019 at 12:14 PM · edited Thu, 26 December 2019 at 12:16 PM
My last work was for amazon kindle I retold the story of the little red riding hood. See it live @ Link I'm not sure if I will make anymore the work can be tedious and unrewarding. I made this one back in 2014 but I have not made a sale :P you can use the amazon Kindle software they have for free and open a free account at amazon kindle.
William_Rivera ( ) posted Tue, 31 December 2019 at 8:45 AM
Good morning anime scientist did you know you are capable of making iPhone covers with your artworks? I leave that research up to you.
My Iphone 11 case
Agent Midori protecting Gravitron City now you can carry her on your iPhone.
William_Rivera ( ) posted Wed, 01 January 2020 at 5:59 PM · edited Wed, 01 January 2020 at 6:00 PM
A closer look at Aiko 1.0 released around February 2002 Discontinued product at Daz Studios.  The readme says:  Been dying to do some anime work, but unable to get the correct anime style right? Well now you can. Aiko (Love Child) by default is a bijin (beautiful woman) with henshin (physical transformation) powers. She is sure to satisfy even the most devout dai fan (anime fan). This character is equipped with the right proportions and abilities to build expressive and personality rich stories in either manga (comic book) or anime (animation).
My renders below:
Aiko 1.0 can be either a guy or a girl.
William_Rivera ( ) posted Wed, 01 January 2020 at 6:02 PM · edited Wed, 01 January 2020 at 6:02 PM
A render I did at Daz's Manga Cafe with Aiko 1.0
MistyLaraCarrara ( ) posted Fri, 03 January 2020 at 10:22 AM
Aiko anime girl in my heart 😘💕
William_Rivera ( ) posted Fri, 03 January 2020 at 12:07 PM
Ok so I made an experiment my anime scientist, I put the head of Aiko 1.0 thats 2002 first aiko figurine with the body of aiko 3.0/kioki because Aiko 1.0 doesn't have much clothing. here is the outcome:
William_Rivera ( ) posted Fri, 03 January 2020 at 12:23 PM
In Carrara you can use Formulas to color hair, the highlight on the character is actually a formula not a texture.
William_Rivera ( ) posted Sat, 04 January 2020 at 3:07 PM · edited Sat, 04 January 2020 at 3:13 PM
Miku Hatsune's Cantarella is made with Aiko 1 and Aiko 3
click link to see video
video
William_Rivera ( ) posted Sat, 11 January 2020 at 12:58 PM
Terai Yuki was a 3DCG Pop idol in Japan
I added Capsces Anime Morph here is the outcome
You can find terai yuki video here https://www.youtube.com/watch?v=7ZWGvhCEKo0
William_Rivera ( ) posted Sat, 11 January 2020 at 3:37 PM
Welcome to Manga Cafe promo image for my thread at Daz https://www.daz3d.com/forums/discussion/295231/welcome-to-manga-cafe/p1 welcome.jpg
William_Rivera ( ) posted Sun, 12 January 2020 at 7:29 PM
Gatchaman is Aiko 3 and A3M3 the Aiko Man
William_Rivera ( ) posted Mon, 24 February 2020 at 9:45 PM
705F24AB-FE57-4AFE-8566-2232D6FA31BF.jpegB704EEBA-69E0-4F20-9267-F1DD2A088933.jpeg4A8E1024-022B-487A-B3D4-56FC71E70572.jpeg36BF1FAE-3F68-4015-A1F9-7E7A68A48A01.jpeg56875761-7665-44E1-8DED-10B654185350.jpeg88B80C41-A25E-4644-997B-51A22CD426F0.jpegDC19C1A4-6CF7-49B5-BD28-0C8FF6BDEEF4.jpeg
William_Rivera ( ) posted Tue, 03 March 2020 at 12:51 PM
Im a nurse in real life wanted to give some advise about this novel corona virus, please wash your hands and dont touch your faces, always carry a hand sanitizer and avoid touching public buttons such as ATM machines and Elevator buttons please use a Qtip or a tongue depressor if you have to touch buttons, don't clean bird poop off your cars those are the disease carriers.
MistyLaraCarrara ( ) posted Fri, 20 March 2020 at 7:29 AM
this is good info for the current anime contest. Thanks!
William_Rivera ( ) posted Sun, 10 May 2020 at 2:32 PM
My children book fables, stories and legends will soon be available in amazon kindle by next week, it features original children stories. All detailed and in 3D, I ill post a link on Saturday May 16 that day will be the freebie day for the book. so be on the look out, the book has 36 pages of original children stories.
William_Rivera ( ) posted Sun, 10 May 2020 at 11:26 PM · edited Sun, 10 May 2020 at 11:32 PM
I didn’t made it to the finals on the anime contest I’ll try harder next time.37460834-E305-4CF7-886B-0210A8E6542D.jpeg
Gravatitan a super robot protecting Gravitron City made of the strongest metal in the universe kierro, piloted by Gravuitas an enhaced android. Gravuitas is supported by her butler Hokkan, Monanitas the Maid, Jeek the student, Kora the Catgirl, Jyuna the student and Jerona the Pop idol. Together they fight against the evil mastermind Grokkas and his evil crew.
To describe the image, most aspects of Japanese anime is included on this image, you see a Butler, a maid, a giant robot, an android, a cat girl, a schoolgirl, a schoolboy and a pop idol. Moreover a good solid introduction. Best of luck to everyone.
William_Rivera ( ) posted Mon, 22 June 2020 at 11:14 PM
Anime and Manga
diomede ( ) posted Sun, 28 June 2020 at 1:32 PM
Bold characters. Looks great.
William_Rivera ( ) posted Tue, 08 September 2020 at 10:02 AM
Thanks I have made some more characters but I have placed them on my site @ https://3dcgx.com feel free to visit.
William_Rivera ( ) posted Wed, 09 September 2020 at 9:56 AM · edited Wed, 09 September 2020 at 9:57 AM
I have used Carrara for some time now I use it for Anime renders, I have thread over by the Daz3D art studios called anime cafe.; Now because of Carrara limit on genesis I have used Kioki Aiko 3 is more of an anime type of base model with many morphs.; Carrara is great for anime renders, not so realistic just perfect.
William_Rivera ( ) posted Sun, 13 September 2020 at 7:55 PM
William_Rivera ( ) posted Sun, 24 January 2021 at 11:09 AM
Jinn as AeroDoll
Jinn is an aiko 3 model rendered in carrara
William_Rivera ( ) posted Sun, 24 January 2021 at 11:52 AM
Jinn as Tifa
William_Rivera ( ) posted Sun, 24 January 2021 at 12:01 PM · edited Sun, 24 January 2021 at 12:03 PM
Jinn as Cammy
William_Rivera ( ) posted Tue, 26 January 2021 at 2:29 PM · edited Tue, 26 January 2021 at 2:31 PM
and this can go on, so far I counted about 350 outfits with Aiko 3 and that not counting the outfits of my friend Idelacio @ idelacio he has 1.100 outfit combination with Aiko 3 he has an endless thread there, therefore with all this I have no need of genesis. i have an endless website of outfits at 3dcgx
MistyLaraCarrara ( ) posted Sun, 04 April 2021 at 5:51 PM
Aiko means heart.i havent figured out if kawaii means something. tho i did learn what yaoi means, but not how to pronounce it.
