Wed, Jan 8, 7:00 AM CST
Subject: Free Texture Generating Tool.
quietrob ( ) posted Fri, 13 December 2019 at 5:02 PM · edited Wed, 08 January 2025 at 6:57 AM
It is called Materialize. It is, as stated in the title, a free Texture Generating Tool.
It is standalone and currently for Windows users only. Mac and Linux are out of luck at this time. It looks like it's for props but I'm betting some of the pros can use this for figures as well. Here are the links. Mods feel free to move this where you wish. I'm just following Earl's propensity for sharing useful links and Apps with the community. The first two links tells you all about it and the third link is the download page itself.
https://www.gamefromscratch.com/post/2018/10/16/Materialize-Free-Texture-Map-Generation-Tool-Released.aspx
https://www.youtube.com/watch?v=vtnJToPxBNo
http://www.boundingboxsoftware.com/materialize/getkey.php
It's also available for Unity and the Unreal engine.
Boni ( ) posted Fri, 13 December 2019 at 5:24 PM
Cool! Thanks Rob!!
Boni
gate ( ) posted Fri, 13 December 2019 at 5:30 PM
Ok That can be really useful for sure " Thank You "
hborre ( ) posted Fri, 13 December 2019 at 5:32 PM
I have used this free program for the last several months now and it seems to do a decent job. It doesn't quite generate textures from scratch, it creates bump, normal, specular and displacement maps for an existing texture map. Fun to play with and practical if you want to fine-tune specific maps or generate maps that don't exist otherwise.
ghostship2 ( ) posted Fri, 13 December 2019 at 5:53 PM
very cool.
wheatpenny ( ) posted Fri, 13 December 2019 at 6:22 PM
Site Admin
@quietrob, posts of this kind are fine here, in fact we encourage them. Thanks for sharing.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
SamTherapy ( ) posted Fri, 13 December 2019 at 7:26 PM
Cheers, bloke!
Miss B ( ) posted Fri, 13 December 2019 at 11:12 PM
hborre posted at 12:09AM Sat, 14 December 2019 - #4373293
On the site it says for use in games, so is the quality good enough for use in high end renders from Poser, DS, ZBrush, or whatever 3D app(s) you prefer to use?
_______________
Butterfly Dezignz
hborre ( ) posted Sat, 14 December 2019 at 11:14 PM · edited Sat, 14 December 2019 at 11:15 PM
This is a render of EL Grey Alien with bump, normal and specular maps generated through Materializer. Tweeted the skin color in photoshop and rendered in Superfly.
jartz ( ) posted Sun, 15 December 2019 at 1:56 AM
That's very good, hborre. I've been struggling to get better bump, normal and specular maps in Materialize. I just wish there was a tut that would do that.
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
Miss B ( ) posted Sun, 15 December 2019 at 8:21 AM
Thanks for the render hborre. That gives me an idea of what can be accomplished, as I'm not into gaming, which usually means lower resolution graphics than what I'm used to in the 3D apps I use regularly.
_______________
Butterfly Dezignz
bagginsbill ( ) posted Sun, 15 December 2019 at 8:57 AM · edited Sun, 15 December 2019 at 9:01 AM
These tools work when they work and don't when they don't. Your level of 3D sophistication and discernment will determine the suitability for your purpose.
This is a screen cap from a video showing how "great" this works. The author doesn't even acknowledge the ridiculous distortion of this otherwise perfectly circular and flat object. This is not a fault of this program, but rather of the entire premise - you cannot produce accurate maps from a single diffuse photo.
It generally is suitable for "natural" surfaces where you cannot actually tell which shapes are right or wrong. For man-made surfaces that are clearly not irregular in shape, it gives results that are not correct.
Try it on this:
bagginsbill ( ) posted Sun, 15 December 2019 at 9:15 AM · edited Sun, 15 December 2019 at 9:15 AM
LOL
Miss B ( ) posted Sun, 15 December 2019 at 9:47 AM
WOW, those look like deflated balloons.
_______________
Butterfly Dezignz
