Mon, Jan 20, 11:31 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
Subject: 11.2 Joint Editor - inner/outer mat sphere display
movida ( ) posted Fri, 20 December 2019 at 7:52 AM · edited Mon, 20 January 2025 at 11:19 AM
In 11.2 the inner/outer mat sphere displays like a low polygon wireframe - my Poser Pro's 2012 and 2014 are fine this is only ll.1. Anybody have any ideas it bugs me :) Thankssphere.jpg
movida ( ) posted Fri, 20 December 2019 at 7:54 AM
It's 11.2 involved. It won't let me edit :)
adzan ( ) posted Fri, 20 December 2019 at 12:31 PM · edited Fri, 20 December 2019 at 12:37 PM
Hi. The object that Poser 11 and Poser 2014 uses to display the sphere zones was changed.
So yes you are correct, Poser 11 does use a lower polygon model to display the inner and outer zones.
You could change it, it is reasonably easy to do - But - it will be replaced with the low poly version each time you update poser and as Bondware have issued 3 updates since they bought poser then you might be replacing it more often than you would have when Smith Micro owned it.
If you're adamant it annoys you enough to change it then here's how.
Go to the your poser 11 content folder/Runtime/Geometries/props and make a copy of or rename the ball.obz file.
Then copy the ball.obz from your Poser 2014 prop folder to your Poser 11 prop folder.
Tada all done. Yep that easy to change.
Advice : Always make backups before changing files as any changes are at your own risk.
movida ( ) posted Fri, 20 December 2019 at 12:53 PM
Hi adzan and thanks for the reply. I'll try it in a while. How'd you know that lmao?
movida ( ) posted Fri, 20 December 2019 at 1:11 PM
