Sun, Dec 29, 1:42 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Demonstrating simple wx.SingleChoiceDialog and wx.MultiChoiceDialog
adp001 ( ) posted Fri, 27 December 2019 at 6:48 AM · edited Sun, 29 December 2024 at 1:32 PM
import wx
try:
    import poser
except ImportError:
    raise RuntimeError("Script must run in Poser.")
def generate_names(obj_list):
    if hasattr(obj_list, "__iter__"):
        for obj in obj_list:
            if hasattr(obj, "Name"):
                yield obj.Name()
def actor_choice(choicelist=None):
    Demonstrates wx.control SingleChoiceDialog
    if choicelist is None:
        choicelist = poser.Scene().Actors()
    choices = list(generate_names(choicelist))
    with wx.SingleChoiceDialog(None,
                               caption="My Actor Dialog",
                               message="Select one actor",
                               choices=choices,
                               style=wx.CHOICEDLG_STYLE
                               ) as dlg:
        if dlg.ShowModal() == wx.ID_OK:
            return dlg.GetStringSelection()
        else:
            return None
def actor_choices(choicelist=None):
    Demonstrates wx.control MultiChoiceDialog
    with wx.MultiChoiceDialog(None,
                              choices=choices,
                              ) as dlg:
            return [choices[i] for i in dlg.GetSelections()]
        else:
            return None
actorname = actor_choice()
print("Selected Actors:", actorname if actorname is not None else "None")
actornames = actor_choices()
print("Selected Actors:", actornames if actornames is not None else "None")
FVerbaas ( ) posted Sat, 28 December 2019 at 9:05 AM
Forum Coordinator
Very convenient!
Thanx for sharing.
adp001 ( ) posted Sat, 28 December 2019 at 10:19 AM
You are welcome!
For the other thread: I think about clothes. Without MD ;)
maur_2005 ( ) posted Wed, 05 February 2020 at 8:13 AM
That very useful, thank you.
one question, how can I add an option that allows me to select all?
adp001 ( ) posted Wed, 05 February 2020 at 9:11 AM
This shows "SingleChoiceDialog" and "MultiChoiceDialog" as it is provided by wxPython as a quick solution. If you need it more complicated, you need to create your own dialog.
But I'm sure I also showed a dialog with "select/deselect all" somewhere :).
