Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Oct 06 3:44 am)
Yes, the basic problem is that we no longer have public changelogs being posted.
My Poser says 11.2.271, and when I when I "Check Now" for updates, I'm told there is one. At the page the 11.2 installer has a date of 10th Nov 2019. However, without changelogs to tell me what's changed / removed / added / fixed, I'm wary of updating.
If I could see a concise list of what's changed, I'd be far more likely to think: "ok that's worth the hassle of downloading 1.2Gb again and re-installing". Or: "no, that's not worth the hassle, I'll wait to the next bigger update".
I did the original update as was required but I use Poser on an almost daily basis so once I have a working installation I tend to hold tight. My whole life I have tended to stick with the maxim the 'if it ain't broke don't try and fix it'. The next time I will update is when I find a problem or when I see some indication of a change that will be beneficial to me and the way I use Poser. The only other update that I might do is Poser 12, or whatever the new release is called, when available. Even then I probably will not be an early adopter thus allowing others to do the testing and bug fix before I upgrade.
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
A new version has just been released, are there any important changes? Is there any information ( Change Log ) would be Important to know as it is a full Installer ! This seems to be handled very Un-Professional. If Changes are handled the way it is released then it might put a Personal Computer at risk!
Install Poser 11.exe 1.3 GB 12-27-2019 10:12 am
Yes, I just saw there's a new downloaded dated 12/27/19 (yesterday). I'll download it, but I'm not sure whether I'll install it. My 11.2.296 is working just fine, thank you very much.
I'd also like to see a Change Log, especially since it's been quite a while since the last update. Several changes within a week or two . . . probably not major updates, but the last time I downloaded an update was 11/27/19, a month earlier, so I have to assume there were some major updates done in that time. It would really be nice to know what has been updated/fixed since last month.
_______________
I'm on a Mac. I just started Poser, and it said there's a new version, but when I go to the page for updates, I only see 11.2.
