Sun, Feb 2, 11:44 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
banner
Subject: XL - eXtended Library not working
AcePyx ( ) posted Sat, 04 January 2020 at 9:50 AM · edited Sun, 02 February 2025 at 11:43 PM
Hi guys, trying to follow Lululee's tutorial to import Genesis content into Poser. Easiest recommended way is using Dimension 3D's XL - eXtended Library software which runs as a python scripted add on. However, no matter which of the 4 or 5 offered ways of running XL I use, it throws up errors and refuses to run.
Any direct scripting method such as "File/Run Python script" generates the following error:
'XLWin' object has no attribute 'xl'
If I run it via the Scripts menu (autostarting with Poser), it produces the following:
Traceback (most recent call last): File "C:GrafikPoser 10 Pro 64RuntimePythonposerScriptsScriptsMenuDimension3DXL.py", line 3059, in the word module is enclosed in diamond brackets here but the forum software keeps erasing it.
File "C:GrafikPoser 10 Pro 64RuntimePythonposerScriptsScriptsMenuDimension3DXL.py", line 3057, in main
File "C:GrafikPoser 10 Pro 64RuntimePythonposerScriptsScriptsMenuDimension3DXL.py", line 26, in init
File "C:GrafikPoser 10 Pro 64RuntimePythonposerScriptsScriptsMenuDimension3DXL.py", line 140, in init
IndexError: list index out of range
Does anyone have this running with Poser 11 Pro, and if so did yu encounter/resolve similar errors?
As a matter of interest, EZ Skin also throws up errors but I can run it.
If these errors are unresolvable, are there other relatively easy ways to import Genesis 3/8 content?
Thanks in advance.
structure ( ) posted Sat, 04 January 2020 at 2:38 PM
Forum Coordinator
... try this script by snarlygribbly - it should fix your XL script issue
Locked Out
AcePyx ( ) posted Sat, 04 January 2020 at 4:52 PM
Glorious! It did indeed. So happy. Thanks.
McGrandpa ( ) posted Fri, 17 January 2020 at 2:08 AM · edited Fri, 17 January 2020 at 2:11 AM
Oh Yeah! You're great Structure! I be a Happy Greatgrandpa over here too. Thanks so much for that. XL is running right now in PP 11.2 Bondware!
My 66th Birthday PC Build (July 1, 2020) :  named BadMoonRYZEN!, W10Pro x64, Octal Core RYZEN7 X3700 4.05 GHz, 64GB DDR4 RAM, GeForce RTX 3060 - 12GB GDDR6, PP2014, PP 11, P12, PS-CS4 Extended & Vue 2024.
McG.
HartyBart ( ) posted Wed, 22 January 2020 at 2:21 PM
For those finding this thread in the future, the same fix also works for Dimension 3D's XA Toolbar.
EnglishBob ( ) posted Thu, 23 January 2020 at 4:00 PM
I'd also add that it fixes the Reality plugin. I now autorun AVfix whenever Poser starts, so it may have fixed other scripts too - I didn't try them all before I installed AVfix. :)
Given that AVfix is (in my view) an essential add-on, I have to wonder why it seems to be a reasonably well-kept secret.
