Blender F.A.Q (Last Updated: 2024 Nov 24 8:44 pm)
If you want to keep the loops in the same proportions, then scaling on the z-axis will do it (ctrl-s, z, [enter number or move mouse]).
If you just want to move the top up, then select all the vertices/edges/faces from the middle to the top (or any number of levels from the top down) and pull it on the z-axis (g, z, [enter number or move mouse]). You can then add more edge loops into the elongated space if you need them.
Or, select all the top faces (only) then extrude (e, z, [enter number or move mouse])
If you want to scale the cube as a whole and make it taller click on "A" to select all then "s" and then "z" to scale it up the z-axis and drag your mouse or you can enter a numeric value by just typing it from the numpad
Lobo3433
I want to make this cube taller. I've selected a loop around the cube (in the middle and at the bottom) but can't seem to figure out what tool gets me there. Extrude and slide loop don't do it.
