Sun, Feb 16, 11:38 AM CST
Subject: La Femme in Bullet Physics Question
tchamberlain2 ( ) posted Fri, 10 January 2020 at 7:35 PM ยท edited Sun, 16 February 2025 at 11:28 AM
I'm curious. Is there a version of La Femme that works with bullet Physics? It seems like every time I put this character in Bullet Physics I can not make soft body dynamics happen. Is there a version of her that will work with it? Maybe I'm missing something! I don't know! Does anybody know anything?
EClark1894 ( ) posted Fri, 10 January 2020 at 8:00 PM ยท edited Fri, 10 January 2020 at 8:01 PM
What is it you're trying to do? I think I know, but I want to be sure.
tchamberlain2 ( ) posted Sat, 11 January 2020 at 2:56 PM
Well, soft body dynamics. If I want to make her stomach, breast, thighs or any thing on her body to dynamically move. If I want to make her fall into a blob in the program. You know soft body dynamics. What you can do with Roxie, V4, Dawn and some of the others.
Afrodite-Ohki ( ) posted Sat, 11 January 2020 at 5:51 PM
I've never tried to use soft body dynamics, so I can't help you, but I'm curious - what happens when you try to use it with LF?
- - - - - -ย
Feel free to call me Ohki!
tchamberlain2 ( ) posted Sat, 11 January 2020 at 6:35 PM ยท edited Sat, 11 January 2020 at 6:38 PM
They don't appear to work on LF (when you try to use them in Bullet Physics)? When you select the body sections in bullet that you are trying to put dynamic weight (to calculate and animate the simulation) it just stays the same. Never dynamically moves when you press Calculate Simulation! It won't work for any body dynamics on LF! Not Stomach, Breast or anything you highlight to make a simulation on her body! Has any one ever got any form of LF body dynamics in through bullet physics? I'm trying to break through! Or can a version of her be created that works in Bullet Physics?
EClark1894 ( ) posted Sat, 11 January 2020 at 6:50 PM
So I had some time tonight and decided to see what the problem with La Femme is in Bullet Physics. I selected Bullet Physics and opened it up. I only had two objects in the scene. La Femme and the Ground. The Ground went under Choreographed. Ground ALWAYS go under Choreographed. it doesn't do anything and it's not supposed to move. La Femme went under soft bodies. Make sure you check the box to add her to that group. Next I made sure that La Femme was listed in the objects in the scene. and I clicked on Live Simulation. She collapsed into a puddle of goo. Now, assuming you want certain parts of her to "jiggle" or bounce when she walks, you'll need to expand the Hierarchy editor and select that body part to work on. Then you'll probably have to experiment a little to find the right settings. I rarely use Bullet Physics and don't really make breasts jiggle at all, so I couldn't tell you what those settings are.
EClark1894 ( ) posted Sat, 11 January 2020 at 7:26 PM
Okay, so I tried to find some videos on Soft Body Physics in Poser. This is the only one I could find. Now, this is a training course, and they say that there's a whole course on this, but you'll will apparently have to sign up to view more than this video.
I didn't want to break any renderosity rules and I'm splitting major hairs by posting this address, but it does lead to YouTube, the video apparently features Mark Bremmer, Renderosity's video Tutorial guy, so if you want more info, you can ask him.
https://www.youtube.com/watch?v=s0-28hyiugA&t=272s
tchamberlain2 ( ) posted Tue, 14 January 2020 at 10:25 AM
Yeah... Thanks for the infio in tutorials. I can't tell if there is anything I am doing from what you did different. It all looks the same to me. However, I'm just not getting any physics with La Femme (like all the other characters I have been able to use). I wonder if you used a different version of her then I?
EClark1894 ( ) posted Tue, 14 January 2020 at 1:28 PM
I used the version that came with 11.2. It's the only one I have.
tchamberlain2 ( ) posted Tue, 14 January 2020 at 1:45 PM
The one that Poser 11.2 Loads with?
tchamberlain2 ( ) posted Thu, 23 January 2020 at 3:26 PM ยท edited Thu, 23 January 2020 at 3:28 PM
Ok!! I finally got soft body dynamics for La Femme to work with Bullet Physics in Poser 11.2. It took me opening an older version of her that I saved on Poser 10. I then ran the old version of her through Bullet Physics and then it all worked. She was able to dynamically melt to the ground in one test. I also, (eventually) was able to get soft body dynamics on parts of her body like the breast. I think for all the other characters that didn't work like GND Anastasia, I'll try to do the same thing. Open an older version of her. I think something is wrong with most of all my new characters (in Poser 11.2) working in Bullet Physics. I have to open them in a older saved version of them, then work from there! Thanks for all of your help!
EClark1894 ( ) posted Thu, 23 January 2020 at 7:36 PM
Glad you got it working. And sorry I missed your earlier post, but yeah, 11.2 is the only La Femme I have. I don't usually jump on figures when they first come out. I sit back and see how they do first.
AmethystPendant ( ) posted Fri, 24 January 2020 at 2:46 AM
Just out of interest, what skinning method / SubDiv levels if unimesh are you using when doing your tests.
EClark1894 ( ) posted Fri, 24 January 2020 at 10:17 AM
If you're talking to me, mine was at the default. I rarely mess with the skinning methods.
tchamberlain2 ( ) posted Fri, 24 January 2020 at 10:59 AM
Same here. I don't mess with the skin meth.
