Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 22 10:18 pm)
Etep; HI - I just tried it & download starts okay for me; Couple of things you can try - From your comments, it sounds like you're getting INTO the site, but just can't DOWNLOAD Celine. If that's true, assuming you use windows, go back again, & if downloading doesn't start from a simple click, try Right-Clicking on the download button, then select "Save Target as..." from the popup menu & eight times out of ten, that'll do it. If you just can't get into the site, it's likely a problem between your ISP & his, or some setting in your browser is getting in the way (java or javascripting turned off, or corrupted in your install, etc.) If that's the case, perhaps you can EMail Michael2 to EMail it back to you? Good luck!
Attached Link: http://members.tripod.de/poserfun/index.htm
Celine with Femina Gen Morph Set and my new Texture for Vicky is ready and cant Download from my Website.On the Image you cant see Celine with the new High Detailed Texture for Vicky.
