Hello. I found this free bit of graphic software that you can make really small images down to pixel level, like the size you mention. GraphicsGale it is really useful for making the smallest tiled seamless textures if you get cleaver with it. Thanks. Pat :)
@ Anthony Appleyard: That's a really interesting concept for fabrics. Definitely worth more playing with it (maybe even 4x4px for more detail?) Thank you for this post!
@ ghostship2: Maybe the compression "ate" your details. But I know how this will work in closeups because I also use this a lot when retexturing clothes. The caveat is in setting the right size of the weave, which isn't easy because Poser has no RW scale and we have to resort to guess & try. We can either end up with fine silk, or a coarse potato sack :D
K
In this model, the woven kevlar thread texture is made using the smallest bump map that ever was :: 2 x 2 pixels! Its 4 pixels are laid out checkered black and white. The bump map is applied U_Scale = V_Scale = 0.002, texture strength=1, tiled.
