I've just installed the 'basic' Pro 11.3, happily retaining my modest library from 11.2. Hey ! And my un-saved trial renders !!
Took a lonnng time to load, but could have been scanning library etc. Took a couple of minutes to respond to the UI dot to switch to my preferred screen size, used a complete CPU core and ~96+% of GPU. Similarly, took ~30 secs to respond to simplest command.
After a while, I noticed the view was changing without my input. The camera was very, very slowly tilting upwards so that, instead of LaFemme in mid-screen, the ground grid-lines were vanishing off the bottom edge, one by one, followed by her feet, her ankles, her knees. And, perhaps, the camera was progressively tilting, too...
Happens I've seen such before, following an FBX import that went horribly wrong. So, I hit the animation toolbar's 'stop' button, turned 'loop' off. And then RESTORE ALL to pull the scene back. Yeah, prompt control functions restored....
How can I prevent this anomalous excursion ??
Hi ! Any-one else having Poser problems since last week's big Win'10 x64 update ?
Response slowed to crawl, menus freeze, totally chokes after eg FBX imports, won't shut down from [X] or toolbar, needs hard-kill via task manager. Just taken ~30 secs to respond to UI button after starting. And now, similar delay switching between editing tools...
It's not for lack of system resource, there's 32 GB RAM and an Amd FX-8350 with 8 cores. No obvious memory leaks. But any Poser command sends CPU from 6% to 20% for those ~30 secs.
Funny thing, P is 11.2.286, but claims an update available. This before the 11.3 roll-out...
Have also had problems with Moz' usually benign T-Bird unable to delete unwanted mail. A restart usually fixes that, but PC was off overnight,
Nik
