Mon, Feb 3, 6:16 PM CST
Subject: How do you unhide parameter dials that have been hidden?
dlk30341 ( ) posted Thu, 12 April 2007 at 6:38 PM · edited Sun, 26 January 2025 at 7:11 PM
As stated above.
ockham ( ) posted Thu, 12 April 2007 at 6:49 PM
Here's a little Python script to do it quick and dirty.  I think Les Bentley has
some pose files that do the same....
http://ockhamsbungalow.com/Python/UnHideParms.zip
My python page
My ShareCG freebies
pjz99 ( ) posted Thu, 12 April 2007 at 7:33 PM
If you know the name of the parameter, you can write a pose file along these lines:
http://www.david.eaton.ukgateway.net/RevealScaleDials.zip
My Freebies
iloco ( ) posted Thu, 12 April 2007 at 7:36 PM
Thanks for the unhide link.
If I have a prop in poser and it has a lot of parts is there a way to group all the files so can use the unhide dials only one time insteaad of having to check each file and then run the script.
ïÏøçö
pjz99 ( ) posted Thu, 12 April 2007 at 7:44 PM
Basically get stuff un-hidden the way you want it to be, and re-save the prop into the library, if I understand you right.  The dials will be visible when you load the newly-saved prop.
My Freebies
iloco ( ) posted Thu, 12 April 2007 at 7:47 PM
My questions is in my props collection I have a model with lots of parts and I have to select each part and run the python script for each part which is time consuming.
 Is there a way to group all the parts and run the phyton script only one time to unhide the dials for all the parts.
Thanks for replys.
ïÏøçö
pjz99 ( ) posted Thu, 12 April 2007 at 8:04 PM
As written, no, doesn't look like it.  You'd only have to do it the one time and re-save the prop though.
My Freebies
iloco ( ) posted Thu, 12 April 2007 at 8:37 PM
Ok, Thanks. I understand
Maybe someone can write a script that will do them all at once. :)
ïÏøçö
alamanos ( ) posted Thu, 12 April 2007 at 9:32 PM · edited Thu, 12 April 2007 at 9:34 PM
you can use wordpad
open the uncompressed file, do a search  and replace all
hidden 1 replace with hidden 0
line will look like this
initValue -0.017
hidden 0
forceLimits 0
min -100000
max 100000
iloco ( ) posted Fri, 13 April 2007 at 6:25 AM · edited Fri, 13 April 2007 at 6:26 AM
Thanks for the notepad information.  Using UltriEdit I can do them all with one click. This is what I was looking for. :)
Much faster than doing one at a time with the python script. :)
ïÏøçö
dlk30341 ( ) posted Fri, 13 April 2007 at 8:55 AM
Thanks for the info :) Great work!
AbeJackson ( ) posted Wed, 15 April 2020 at 7:25 PM
I accidentally floated the parameter dial and now I can't find it even though it is checked in the window options.
hborre ( ) posted Wed, 15 April 2020 at 11:12 PM
If checking off and back on doesn't bring it back and you didn't save a UI dot, I'm afraid you will need to set it back to factory settings under General Preferences.
structure ( ) posted Thu, 16 April 2020 at 8:34 PM
Forum Coordinator
If you're using poser 11
Locked Out
hborre ( ) posted Thu, 16 April 2020 at 10:58 PM
Wait a minute, are you sure that restores the hidden panel or does it only unhides the dials? I believe the post mentions a floating panel behind the main UI.
structure ( ) posted Thu, 16 April 2020 at 11:23 PM
Forum Coordinator
the OP mentions no such thing :)
Locked Out
structure ( ) posted Thu, 16 April 2020 at 11:25 PM
Forum Coordinator
if you have lost a panel - the easiest way to restore it is to go to
Edit > General Preferences >
check Launch To Factory State and restart poser
Locked Out
KarinaKiev ( ) posted Sun, 19 April 2020 at 2:21 AM
Unfortunately this will eliminate all your custom UI setup! So basically you're back to Poser5 interface...
I'd rather suggest to try to fix your problem by manually editing the poser.ini file or some such.
Too tired this early morning to look which file and which parameter you need to edit, but I hope some others will chime in with a solution.
K
AbeJackson ( ) posted Mon, 27 April 2020 at 7:54 PM
well the parameter dial suddenly reappeared in its original position. Thanks for all the responses.
