Sun, Feb 2, 2:47 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Subject: Problem with Victoria
mdbruffy ( ) posted Thu, 23 April 2020 at 5:06 PM · edited Sun, 02 February 2025 at 2:47 PM
Could someone please tell me why or how the face morphs for V3 would freeze up and not respond? I'm using P11.3.740 on Windows 10.
As you can see, both "Part lips" and "MouthSpeak" are turned up and there's no reaction.
SamTherapy ( ) posted Fri, 24 April 2020 at 5:53 AM
I don't know what causes it but it's happened to me before now. The only solution I found was a restart.
I filed it under "Poser does weird stuff sometimes".
Doc000 ( ) posted Fri, 24 April 2020 at 6:51 AM
I've had this happen before on some figures (mostly V3 and that whole generation of figures). I usually just re-inject the morph(s) and that fixes it.
RedPhantom ( ) posted Fri, 24 April 2020 at 7:44 AM
Site Admin
I didn't test on V3, but earlier, I was using M3 and tried to load a character morph that used various injection morphs and when I injected it, many of the morphs stopped working. I ended up loading 2 figures, applying the character to one and copied each value to the other by hand. I don't know if other charcters to the same, Since this just started, I wonder if there isn't a bug in the lastest update.
mdbruffy ( ) posted Fri, 24 April 2020 at 3:12 PM
RedPhantom posted at 3:11PM Fri, 24 April 2020 - #4387163
No bug. I've had this happen with earlier versions of Poser. I'll try a re-start, if that doesn't work, it looks like re-injecting the morphs will be the only option.
mdbruffy ( ) posted Fri, 24 April 2020 at 7:20 PM
I've tried to re-inject the morphs and it did no good.
infinity10 ( ) posted Sat, 25 April 2020 at 12:53 AM
More than one installation of V4 and V4 Morphs will cause confusion. One solution is to run the Daz3D-provided BAT file which informs software to look for the morphs in a specific location. Or uninstall the duplicates. I find that running the bat file helpe sort out the trouble.
Eternal Hobbyist
SamTherapy ( ) posted Sat, 25 April 2020 at 7:11 AM
infinity10 posted at 1:11PM Sat, 25 April 2020 - #4387259
Talking about V3 here, mate.
SamTherapy ( ) posted Sat, 25 April 2020 at 7:17 AM · edited Sat, 25 April 2020 at 7:17 AM
mdbruffy posted at 1:14PM Sat, 25 April 2020 - #4387236
Have you tried this?
Start Poser
Load V3
Inject morphs
Save V3 with morphs
Exit Poser
Restart Poser
Load morphed V3
I almost always use V3 with all morphs preloaded; I've encountered problems when injecting morphs into a figure in an existing scene, or if Poser's been running for a while.
mdbruffy ( ) posted Sat, 25 April 2020 at 9:21 AM
I have several files of V3 in my runtime. I've gone back to an older version of her with the morphs and they work. So I guess I'll have to go back and apply my textures and the hair to this figure. Working V3.jpg
mdbruffy ( ) posted Sat, 25 April 2020 at 11:32 AM
That worked. Using the older file seemed to do okay.
