Sun, Feb 2, 2:57 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
banner
Subject: Area lights with Firefly
Doc000 ( ) posted Sat, 23 May 2020 at 4:31 PM · edited Sun, 02 February 2025 at 2:56 PM
This may be a silly question, but do Area Lights function with Firefly?
I'm specifically wondering about the shadow strength...there seems to be no way to adjust it. I either get a really strong, dark shadow or I can turn it off. Turning the shadow strength down to practically nothing still results in a strong shadow.
Do they even work with Firefily?
LeeMoon ( ) posted Sat, 23 May 2020 at 5:31 PM · edited Sat, 23 May 2020 at 5:34 PM
Hi Doc000! I just ran a quick test in Poser Pro 11 using 3 area lights. They do work in FireFly.
The sample scene I set up generated soft and moderately dark shadows.
Try setting the intensity of your area light(s) higher and also scale them larger to get soft shadows while maintaining relative brightness. Move it/them further or closer to the objects you want lit to further "tune" the intensity and/or softness of the shadows.
The Shadow dial doesn't do anything that I can tell with respect to area lights. I believe you need to adjust the area light intensity and size of the area light.
It's been a while since I've rendered with Firefly, so you might want to start with a simple scene using my suggestions to see how it works.
I'm sure others with more experience and knowledge will come along with a lot more useful information.
Hope this helps some!
Doc000 ( ) posted Sat, 23 May 2020 at 7:20 PM
LeeMoon posted at 7:16PM Sat, 23 May 2020 - #4389959
Lee!
When you mention scaling the light, were you adjusting the actual scale settings on the light? And since these use ray traced shadows, did you adjust the settings at all or just go with the defaults? (And the image you posted is the look I'm trying to achieve.)
LeeMoon ( ) posted Sat, 23 May 2020 at 8:14 PM · edited Sat, 23 May 2020 at 8:15 PM
Doc000 posted at 8:10PM Sat, 23 May 2020 - #4389967
Yep, just scale the lights with the Scale Dial -or- use the Scale X and/or Scale Y dials if you need a tall or wide light. Seems like I had intensity set at around 250% on at least one of the lights and scaled the lights up to around 200%-300%, but I might be off on those. I don't remember if I adjusted the area light properties much. I'm currently running a render, but will check my test scene when it's done and post settings.
Lee
LeeMoon ( ) posted Sat, 23 May 2020 at 8:31 PM · edited Sat, 23 May 2020 at 8:34 PM
In my test scene, the primary light points directly at the urn (used Point At) and casts the shadow on the wall.
The relevant dials for it are as follows:
xScale 349%
yScale 582%
scale 211%
intensity 250%
xtran 0.000
ytran 8.000
ztran 21.000
The other 2 area lights in my scene are very low intensity and were just for side key lighting.
Lee
Doc000 ( ) posted Sat, 23 May 2020 at 9:56 PM
LeeMoon posted at 9:55PM Sat, 23 May 2020 - #4389977
xScale 349%
yScale 582%
scale 211%
intensity 250%
xtran 0.000
ytran 8.000
ztran 21.000
Lee
Cool...thanks! I'll test it out when I get a chance.
LeeMoon ( ) posted Sat, 23 May 2020 at 10:37 PM
Doc000 posted at 10:36PM Sat, 23 May 2020 - #4389986
Excellent! I hope it works out for you and you get the renders you're looking for.
Lee
structure ( ) posted Sun, 24 May 2020 at 3:12 AM
Forum Coordinator
Area Lights not only work in Firefly, they work in poser 10 also
Locked Out
