Fri, Jan 10, 5:47 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 10 2:22 pm)
banner
Subject: Mangled figures in poser 11 after deson export from daz studio
Tucan-Tiki ( ) posted Sun, 24 May 2020 at 2:10 AM · edited Fri, 10 January 2025 at 3:14 PM
loaded a figure that previously worked now suddenly it loads mangled and all twisted out of shape, what's the fix for this?
Tucan-Tiki ( ) posted Sun, 24 May 2020 at 8:20 AM
Ok I tried resetting the figure fine it does however when I move the arm it distorts
All the figures saved from this one in poser are acting the same other figures I exported out of Daz studio are fine, which makes me think the figure I exported is the problem if I didn't know any better I would think the figure is acting as if it had been moved from where poser says it's bones is supposed to be, so I exported the figure And made new companion poser file with the same name hoping that would solve the problem it didn't and the weight mapping general to triaxx, the new figure acts fine but the saved figures still get spaghettified when loading, I still think that all these figures are connected to one file that acts soon all of them and now I'm thinking it's in a folder in the main directory I'm guessing if I delete it and then export again it might solve the problem, I forget what it's called but I'll know it when I go look again, I'm certain it's a file now that's corrupt, how the new figure seems to be immune is probably because it was given a different file that's not connected to the others that are made from the very same figure so poser must have numbered it I think.
Tucan-Tiki ( ) posted Sun, 24 May 2020 at 8:31 AM
I may have to uninstall poser completely and just move my runtime back, Not sure what the issue is.
Tucan-Tiki ( ) posted Sun, 24 May 2020 at 6:56 PM
Might be a weight map issue, it's possible I exported the figure several times, bit that doesn't explain why poser 11.3 crashes and closes intermittently when I load one of those figures, or delete it or choose new scene while the figure is loaded.
Tucan-Tiki ( ) posted Sun, 24 May 2020 at 6:58 PM
Might be a weight map issue, it's possible I exported the figure several times, but that doesn't explain why poser 11.3 crashes and closes intermittently whenever I load one of those anomalous figures, or delete it or choose new scene while the figure is loaded.
Tucan-Tiki ( ) posted Mon, 25 May 2020 at 7:06 AM
Ok Daz is not installing new content but it does load already installed content into the scene, I think I found the problem I reinstalled the Daz installer that's not the problem, it's a bad install of Daz somehow it went corrupt I don't how but it's not communicating with the dim installer, none of my morphs for any Genesis figure is showing up, since that's the figure I'm having trouble with I now suspect Daz isn't communicating with dson through poser so it's acting like the files are corrupted in the deltas for genesies I think, so basically I have reinstall Daz studio again and download all my content which takes hours to download.
