Thu, Jan 9, 8:51 AM CST
Subject: Stupid mistake in Poser 11 - Help !
freyfaxi62 ( ) posted Sun, 24 May 2020 at 8:38 PM ยท edited Mon, 06 January 2025 at 2:31 PM
I don't know what I did..I obvious accidentally changed something :( Can anyone tell me how to return to the default setting for Poser 11 ( and no..reset to factory state is doing anything :) At the moment, see the pic below for what I'm getting every time every time I open a new project window.!Poser Interfac.jpg
structure ( ) posted Sun, 24 May 2020 at 8:51 PM
Forum Coordinator
open general preferences
select launch to factory state
is the usual way to fix UI issues.
If you are talking about super glossy la femme - make sure your render engine is set to superfly
Locked Out
Nails60 ( ) posted Mon, 25 May 2020 at 5:04 AM
It looks like you have switched from open gl to sreed. Right click on the display window and ensure open gl is selected.
an0malaus ( ) posted Mon, 25 May 2020 at 5:57 AM
What Nails60 said. Exactly.
My ShareCG Stuff
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
ironsoul ( ) posted Mon, 25 May 2020 at 6:07 AM
Another thought is hardware shading has been disabled.
KarinaKiev ( ) posted Mon, 25 May 2020 at 10:01 AM
@ironsoul:
You may be right, but from the look (the shiny surface of the figure) it looks exactly like a SreeD preview. And it's easy to accidentally switch from OpenGL to SreeD - just one wrong click in the preview port...
But this can't be resurrected with a "factory state" reload because it's saved in Poser's .INI file, not the preferences.
So to go back, right-click somewhere in the preview and in the drop-down menu that appears --> check "OpenGL"
freyfaxi62 ( ) posted Mon, 25 May 2020 at 3:25 PM
Thank you peoples for the quick replies. Yes..Nails80 was the first to give the answer. I must have accidentally switched from OpenGL to Sreed. . Problem solved now :)
