Mon, Jan 6, 11:18 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Dec 30 12:17 pm)
banner
Subject: Where are the renders stored?
RAMWorks ( ) posted Sun, 07 June 2020 at 2:01 PM · edited Mon, 06 January 2025 at 11:03 PM
Hi,
I've looked ALL OVER for the path to where the renders are stored. I'd like a way to go to that location and quickly delete the ones I don't want and keep the ones I do like. After a kazillion test renders it's a bit much to wade through one at a time.
Thank you Richard
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
ironsoul ( ) posted Sun, 07 June 2020 at 2:43 PM
It its the rendercache its located in your users directory
C:UsersusernameAppDataRoamingPoser Pro11RenderCache
hborre ( ) posted Sun, 07 June 2020 at 3:55 PM
You can also right-click each image and delete that way. But if you waited until you accumulated a gazillion images then going into the cache folder is your only option. You can limit the number of images to cache in your General Preferences so you never get overwhelmed.
ironsoul ( ) posted Sun, 07 June 2020 at 4:10 PM
Doh, forgot about the backslashes being deleted.
Below might be clearer
C:/Users/username/AppData/Roaming/Poser Pro11/RenderCache
RAMWorks ( ) posted Sun, 07 June 2020 at 4:20 PM
Yes, eventually found that cache but seems there must be more internal recording going on as the deleted images from the cache are now showing at black boxes which I then had to right click and delete one by one. GRRRRRRRRRR
My Store is HERE
bwldrd ( ) posted Mon, 08 June 2020 at 1:03 AM
Those black boxes show up if you deleted the render cache as you were opening poser, you can just restart poser and they would have been gone.
Consider me insane if you wish, but is your reality any better?
RAMWorks ( ) posted Mon, 08 June 2020 at 11:06 AM
Ah, I see. Thank you! 😁
My Store is HERE
