Tue, Nov 12, 10:56 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: UI Branding
redspark ( ) posted Mon, 15 June 2020 at 8:05 AM · edited Tue, 12 November 2024 at 10:52 PM
Hi,
I'm interested in coding some Python additions to Poser. I haven't done much coding in Python but the example scripts and API manual are fairly helpful. But something I can't seem to find (and may be it's obvious) is guidance on how to brand your UI elements to look like they belong in Poser. I see that Poser has PSD files that seem to contain graphics for different parts of its UI. Does anyone use this same process to make their Python interface look like Poser? Or is there a better way?
Also, is there a way to create new Poser Rooms using Python? Or at the very least extensions that dock to the UI.
Thanks.
James
structure ( ) posted Mon, 15 June 2020 at 11:46 AM
Forum Coordinator
using a UI Builder such as wxglade or wxformbuilder you can guild your UI on a dockable panel,
then using something like
        man = poser.WxAuiManager()
        root = man.GetManagedWindow()
        ui = UI(root)
        man.AddPane(ui, wx.aui.AuiPaneInfo().Caption('%s v%s' % (APPNAME, VERSION)).CaptionVisible().Float().Resizable().DestroyOnClose().Dockable(True).CloseButton(True))
you can make it dock in poser
Locked Out
redspark ( ) posted Mon, 15 June 2020 at 3:45 PM
Thanks. I'll give it a try and see how it works. :)
J
FVerbaas ( ) posted Wed, 17 June 2020 at 4:01 PM
Forum Coordinator
It would be useful if the Poser interface colours and character style were available as a template. Or, alternatively, a matching style that separates addons from native.
