Mon, Feb 3, 5:31 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
banner
Subject: Genesis 2 Work Around
arrow1 ( ) posted Wed, 17 June 2020 at 7:17 PM · edited Mon, 03 February 2025 at 5:28 PM
I have just followed the instructions of exporting Genesis 2 from DAZ Studio to Poser Pro 11.3.818.I have created a separate runtime called Genesis 2 and exported as instructed.I looked into Windows Explorer and all the necessary items are there.Geometries, CR2,PMD etc.However Poser recognizes the folder but says it is empty when it is not! Any suggestions? Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
donnena ( ) posted Wed, 17 June 2020 at 7:24 PM
Online Now!
Screen shot of the folder please?
Poser, however, will deny the existence of any folder NOT named Runtime..... you have to map to whatever folder Contains Runtime
Andy!
HartyBart ( ) posted Wed, 17 June 2020 at 10:32 PM
Could be that the Library just hasn't had time to re-index the new content?
arrow1 ( ) posted Thu, 18 June 2020 at 4:42 PM
All sorted.It was not named runtime and it did take a while to index.Does anyone know with this system of not using DSON how we get hair,poses,clothes and textures across? Cheers
nerd ( ) posted Thu, 18 June 2020 at 7:10 PM
Forum Moderator
Clothes, just use the same steps except choose the Clothing figure type in the DS CR2 export.
Textures won't export well. DS still thinks it's the Poser 9 days. It only exports simple diffuse maps.
Props, including hair are just props, export the OBJ and import that into poser. If the included .mtl file is right it will get the diffuse textures.
For poses apply the pose to a figure in DS. Export the CR2. Then, in Poser import the CR2 and save it as a pose in the library.
arrow1 ( ) posted Thu, 18 June 2020 at 8:19 PM
What is meant by An easy way to get a nice skin shader is to use one of the included La Femme materials and then switch out the maps for the Genesis maps? Cheers
hborre ( ) posted Thu, 18 June 2020 at 9:35 PM
Online Now!
Copy the node arrangement from Le Femme and paste it into the Genesis Material Zones making sure to use the Genesis texture maps instead of Le Femme.
nerd ( ) posted Thu, 18 June 2020 at 9:59 PM
Forum Moderator
  • Load a LaFemme figure and apply one of her skin materials
  • In the advanced material room select all the nodes and copy them.
  • Then select a skin material on the target figure (Genesis)
  • Select all the nodes and REPLACE them (Right click > Replace)
  • Now on each of the texture maps (Diffuse, Bump, Specular) load the corresponding texture for Genesis.
  • Once you have the skin material copy and replace on each of the skin material zones in genesis.
If you're not sure where the texture maps are located you can look at one of the materials on Genesis to see what folder the maps were imported to. Also remember that Genesis figures use 4 maps areas for the skin. Arms, Legs, Torso, Face. The same tricks work for getting nice Eye, teeth and finger nails. Each has a slightly different shader setup.
Some of the texture maps may not be automatically copied from your Studio runtime to the export folder when you export the CR2. If there are missing maps look at the original figure in Studio. On the surface tab you can click browse on one of the texture maps to open the folder where the maps are. Copy all the maps you need to the folder the exporter created.
You will want to save this material to your library once you've converted it. Then you can apply it to any imported Genesis. Also, there's no reason you couldn't share these built up material files as long as you don't include the actual texture maps. The Material collection it's self would be an original work from a copyright point of view.
arrow1 ( ) posted Fri, 19 June 2020 at 12:03 AM
Many Many thanks for your assistance and prompt reply! I will try your suggestion. Cheers
arrow1 ( ) posted Fri, 19 June 2020 at 9:22 PM
I am still confused about putting the textures on Genesis 2 Female from La Femme! After I select and copy La Femme Textures do I also load a Genesis 2 Female into the same scene and copy the textures? Could I have a step by Step screen grab of how to do it? Also where is the select all nodes file? Cheers
hborre ( ) posted Fri, 19 June 2020 at 10:41 PM
Online Now!
As Nerd described in the previous post, this is the way he would do it:
Load both G2F and La Femme and go to the Material Room, selecting a Material Zone. Select all the nodes and copy.
Select your G2F and select a Material Zone. Again Select all nodes through the contextual menu and replace all.
Once you replaced those nodes, find the image map node for the texture which is still from La Femme, open and replace that with the G2F skin Texture.
Afterward, copy and paste those nodes and replace all the other nodes in the other material zones. Change the image map as needed.
hborre ( ) posted Fri, 19 June 2020 at 10:42 PM
Online Now!
That's it in a nutshell. Any issues, let us know.
arrow1 ( ) posted Sun, 21 June 2020 at 7:40 PM
I am still not sure if If I have got this right! Sorry to be a pain but my old brain slows as I get older! CheersLs Femme G2f.jpg
