Sun, Jan 5, 9:45 AM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Dec 30 12:17 pm)
banner
Subject: Deleting figures or props that are not in the render window
jackwryan ( ) posted Tue, 30 June 2020 at 11:56 AM · edited Fri, 13 December 2024 at 8:23 AM
Many assets contain items. like trees or buildings, that will never appear in the final rendered image. Will deleting these unseen items have a noticeable effect on the rendered image? Thanks. - Jack
Boni ( ) posted Tue, 30 June 2020 at 1:15 PM
IF you are looking for realism ... the shadows, ambient and reflective light that comes from these items may effect your scene, if these features are unimportant. It doesn't really matter. Most sets have an option of either loading the complete scene or using just the props you want ... if you prefer that option.
Boni
hborre ( ) posted Tue, 30 June 2020 at 1:17 PM
As I understand it, anything that is outside the boundary of your render camera is not considered in the scope of your final render. You could delete them, but it won't impact on your render time.
HartyBart ( ) posted Thu, 02 July 2020 at 6:12 AM
There are two reasons you might be asking this, jackwryan.
One, you want shadows cast by trees etc on your scene, even when the object is positioned outside the camera-view of your scene. In which case you might use a gobo light that has a pattern on it, and thus casts things like tree shadows. Wikipedia: "A gobo is a stencil or template placed inside or in front of a light source to control the shape of the emitted light." Various sets of these are available, or you can roll your own. You could also do it in post-work, though that might be a bit tricky if the shadow traverses a complex scene.
Second, you might be asking because you want to be sure that stuff outside your scene is not slowing down your render times. In which case just hide/delete the items and do some test renders. Utilities such as SceneToy can give you a handy scene-list, which enables you to mass delete stuff quickly and easily.
ypvs ( ) posted Fri, 03 July 2020 at 5:22 PM · edited Fri, 03 July 2020 at 5:24 PM
If you open the Hierarchy window then you have the option to either hide (click on eye) or delete an object/figure. On a Windows machine you can click and Shift+Click to select a group of objects, then right click to get the delete or Visibility menu
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Windows 7 64 bit, Avast AV, Comodo Firewall
Intel Q9550 Quad Core cpu,  16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
