Sun, Feb 9, 12:32 AM CST
Subject: How to keep only one frame of an (unwanted) animation?
solstice69 ( ) posted Sat, 25 July 2020 at 12:21 PM · edited Sun, 09 February 2025 at 12:32 AM
Hi all,
I am using both Poser Pro 2014 and Poser 11.3 only for single renders. However, I somehow manage to create animations without wanting it. Don't ask me why this happens, I don't know. Now I often create single figures to import them in a new scene. Lately it happens often that, for example, I created my figure fur use in frame 30, while the new scene is still in frame 1. Then the figure is imported as it was in frame 1, not frame 30. When I change the new scene to frame 30, this one figure is as intended but all others not. This is very annoying. So, is there a way to delete the 29 frames before frame 30 in a file? I tried many things already but nothing happens. I can delete frames 2-30, but not keep the single frame I want to use. Is there a way I can do this? Thanks and best, Tobias
Richard60 ( ) posted Sat, 25 July 2020 at 8:25 PM
Using a backup copy open the animation palette and collapse down the figure you want so it is only a single line. Going to frame 30 select that frame on the figure and make sure the check circle is marked for All Elements.. Press the Plus button to make a keyframe for each and every element. This will ensure that all the movements are baked into the frame. Now that all the keys are placed click and hold the mouse button on frame 30 and drag frame 30 to frame 1. That will move the pose for the figure to the beginning and you should be good.
FVerbaas ( ) posted Sun, 26 July 2020 at 3:31 AM
Forum Coordinator
As for the unintended animations: You may have loaded a pose file that contains an animation.
solstice69 ( ) posted Sun, 26 July 2020 at 9:04 AM
Thank you Richards, it worked!!! :-) And FVerbaas, maybe yes, could be!
Best, Tobias
dadt ( ) posted Tue, 04 August 2020 at 2:13 AM
Go to frame 30 and click on edit/memorise/all, then go to frame 1 and edit/restore/all.
bwldrd ( ) posted Tue, 04 August 2020 at 8:38 PM · edited Tue, 04 August 2020 at 8:39 PM
@Dadt .. learn something new every day.. Had never thought about doing that, will have to give it a try later. Have used memorize plenty, but never even paid attention to , All, being there. Thanks for the tip. :)
Consider me insane if you wish, but is your reality any better?
