Mon, Jan 27, 2:43 AM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
banner
Subject: Bringing in Figure or Object into specific place in scene
thartwick1 ( ) posted Sun, 26 July 2020 at 9:37 AM · edited Sun, 26 January 2025 at 10:01 AM
HI all,
I haven't worked with large scenes very much but when I do I've had to search all over the scene to find out where the figure or object was placed when I added it. Once found, then I have to move it to where I want it. Is there an easier way to do this? Can I set a where I want the figure or object to come into the scene. Hopefully what I'm asking makes sense. Thanks for any help!!
Tom
structure ( ) posted Sun, 26 July 2020 at 10:41 AM · edited Sun, 26 July 2020 at 10:44 AM
Forum Coordinator
you can create a pose and save the body transformations - this way you can put back to the exact same place every time
see this thread for finding objects in a large scene.
Locked Out
bwldrd ( ) posted Sun, 26 July 2020 at 1:16 PM · edited Sun, 26 July 2020 at 1:19 PM
Not really for when bringing it in, but once you have an item in you seen an easy way to move it would be Ochams 'snap to' script on his site @ Ocham's Bungalow
Consider me insane if you wish, but is your reality any better?
FVerbaas ( ) posted Sun, 26 July 2020 at 2:06 PM
Forum Coordinator
Wouldn't that be what can be done now with constraints?
thartwick1 ( ) posted Sun, 26 July 2020 at 7:36 PM
structure posted at 7:35PM Sun, 26 July 2020 - #4395301
Thanks!!
bwldrd posted at 7:36PM Sun, 26 July 2020 - #4395306
I'm on a Max so python scripts don't work. Thanks anyway!!!
HartyBart ( ) posted Sun, 26 July 2020 at 9:12 PM
Yes, the "SnapTo" script uses Tkinter as part of the PoserPython script - which means Mac users can't run it. Tkinter is one of the many things not supported by Apple.
But you don't have to miss out on all Python scripts. Open the desired script with a text editor, and look for "Tkinter" near the top. If it's not there, then you can likely run the script. Unless, perhaps Apple has introduced further security-blocks that I've not yet heard about.
thartwick1 ( ) posted Mon, 27 July 2020 at 11:29 AM
HartyBart posted at 11:28AM Mon, 27 July 2020 - #4395327
Thanks for this tip. I did try running it and it does use Tkinter.
