Sat, Nov 30, 11:29 PM CST
Subject: Main Camera Won't Render (all others will)
LordRiven ( ) posted Sat, 22 August 2020 at 11:23 PM ยท edited Mon, 25 November 2024 at 5:58 AM
So I have a bit of a strange problem - my main camera won't render the image. In Superfly and Sketch it just renders a black square, in FireFly it'll render the lighting but nothing else. Every other camera - Aux, Face, From Left, Posing et alia - has zero problem rendering. The problem is just with Main Camera - as though it has been disabled from 'seeing' my figure. Presumably I accidentally pressed a button or tapped out a hotkey - anyone know what it was and how I can undo it?
Kerya ( ) posted Sun, 23 August 2020 at 1:20 AM
I never had that problem, but did you try to Restore it?
Edit / Restore / Camera
It will move the camera back to the original position, set the Focal to original ... maybe it helps?
RedPhantom ( ) posted Sun, 23 August 2020 at 6:41 AM
Site Admin
You might want to check to make sure the camera isn't inside something or something isn't blocking the view of the scene.
EClark1894 ( ) posted Sun, 23 August 2020 at 7:53 AM
RedPhantom posted at 8:50AM Sun, 23 August 2020 - #4397567
I was going to make that suggestion myself, especially if you're at least rendering a black square. Have you tried moving the camera to another position and rendering? Perhaps try moving the camera's X,Y, Z position to match one of the other cameras that is still rendering and see what you get.
EClark1894 ( ) posted Mon, 24 August 2020 at 6:28 AM
Anyone know how this issue turned out?
