Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Nov 14 12:21 pm)
I assume you mean AVFix? by snarlygribbly.
where did you install the scripts?
did you follow the instructions during install?
IMPORTANT: The installation requires you to make changes in the Runtime within the folder in which you installed Poser.
Depending upon on your operating system, and where you have installed Poser, you may need to perform these steps with Administrator privileges.
STEP 1
1.0 Create a folder called Snarlygribbly in the Runtime/Python/poserScripts/ScriptsMenu folder
1.1 Copy the avfix.pyc file into the Snarlygribbly folder
When you have done this you should have this file in your runtime:
Poser SoftwarePoser 11RuntimePythonposerScriptsScriptsMenuSnarlygribblyavfix.pyc
STEP 2 (OPTIONAL)
NB: This step is ONLY NEEDED if you have addons (such as Reality) that need to use this fix.
2.0 Copy the included poserStartup.py file into your Runtime/Python/poserScripts folder, overwriting the existing one.
(NB: If you have modified your poserStartup.py then (a) make sure it is backed up first and (b) modify it by adding lines 5 to 9 from the included poserStartup.py)
Locked Out
When Poser launches, I get an error that says: NULL (or empty) script name to PEPhython engine. I installed the Reality fix and the startup script that came with it. So how do I fix this?
