Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Nov 04 10:44 pm)
For the distortion, you need to turn off the smoothing for the object. Some objects do that with smoothing. On the properties tab, uncheck smooth polygons.
For the cameras, I've found that happens when the camera settings get rather large, usually the scale. I mostly see it with the directional cameras (top etc.) The fix is to reset that camera. make sure the problem camera is active (you're looking through it) and choose edit>restore>camera
Hi. I've had something weird happen lately in Poser Pro 11. Often a camera will freeze during certain documents. Using the camera controls and parameter dials have limited effect. I crank up the sensitivity and nothing happens. A new document works just fine.
Problem 2 Weird Renders. FireFly gives distorted renders. SuperFly works fine. What have I messed up? Will deleting the pref files fix everything?
Thanks, Thebes
