Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
This litle script may help:
import sys
if sys.version_info.major > 2:
basestring = str
else:
range = xrange
SCENE = poser.Scene()
SWAP_FUNCS = ["SwapTop", # 0
"SwapBottom", # 1
"SymmetryLeftToRight", # 2
"SymmetryRightToLeft", # 3
"SymmetryBotLeftToRight", # 4
"SymmetryBotRightToLeft", # 5
"SymmetryTopLeftToRight", # 6
"SymmetryTopRightToLeft", # 7
def do_swap(actor=None, swap_function="SwapTop", keysfromscene=0, startframe=1):
:param actor:
:param swap_function: String, name of the function to use.
:param keysfromscene: Use framekeys from global scene or local actor. 1 == scene, 0 == actor.
:param startframe: Frame nr to start (1 to n)
if actor is None:
actor = SCENE.CurrentActor()
figure = actor.ItsFigure()
if isinstance(swap_function, int):
swap_function = SWAP_FUNCS[swap_function]
if isinstance(swap_function, basestring):
swap = getattr(figure, swap_function, None)
if swap:
SCENE.SelectActor(actor)
nextframe = SCENE.NextKeyFrameAll if keysfromscene == 1 else SCENE.NextKeyFrame
framenr = startframe - 1
while framenr is not None:
SCENE.SetFrame(framenr)
swap(0)
framenr = nextframe()
SCENE.DrawAll()
if __name__ == "__main__":
idx = poser.DialogSimple.AskMenu("Select", "Swap method to use:", SWAP_FUNCS)
if idx is not None:
do_swap(swap_function=idx)
Simplest use: Select actor/figure you want to work with.
Start the script. It will ask for a methode you want to use to swap. For what you decribed, you may want to use "SwapTop". The script selects all keyframes inside the selected actor and performs a swap.
Thanks! I think Swap Top worked pretty well. Only thing I had to manually do was then delete the old key frames for the opposing side and then change the interpolation type to linear, to preserve what I had before, since default is spline.
The code is simple enough to where it can continue to help me understand Python and the Poser methods.
I think that Pose Symmetry - Custom allows you to specify a frame range ... IIRC.
Not approved by Scarfolk Council. For more information please reread. Or visit my local shop.
Hello, I have a sequence of movements that are done with the right arm. The animation is 1144 frames. I basically key the right arm joints at various frames and interpolate for the rest:
For the whole motion, the left arm and everything else is fixed.
I would like to generate a new motion that is the exact mirror of this one.
I noticed that if I use Pose Symmetry -> Swap right and left, that it is only valid for one frame at a time. I thought that maybe swapping every key frame would work, but it does not fully mirror the motion.
Is there a way to do this automatically without too much labor?
Thank you.
