Mon, Jan 20, 11:07 AM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Jan 20 3:39 am)
Subject: Poser Pro 11 tutorial "lighting part 1" - shadows & shadow light cameras
Opie2150 ( ) posted Fri, 30 October 2020 at 11:28 AM · edited Mon, 20 January 2025 at 10:42 AM
The Poser pro 11 tutorial lesson "lighting part 1" demonstrated a figures shadow moving as a newly created spot light is moved. However, when I try to recreate this, I have a ground shadow directly below the figure that moves when I move the figures arms but the ground shadow doesn't move when I move the spot light. The shadow light camera appears to be directly over the figure and it doesn't move when I move the spot light. How do I associate the shadow light camera with the spot light so they at the same point in space and move together? I am running Poser Pro 11.3.818 on a windows 10 machine..
hborre ( ) posted Fri, 30 October 2020 at 12:52 PM
Just to check, do you have your preview set to openGL?
Opie2150 ( ) posted Fri, 30 October 2020 at 1:19 PM
open GL is checked (on)
I also have Ground + Hardware Shadows selected
Nails60 ( ) posted Fri, 30 October 2020 at 1:48 PM
The shadow light camera should move when you move the associated light, but the light will not move when you move the camera. Make sure you have selected the light either in drop down menu top left document window or by clicking on it in the lights pallet and then select the correct shadow cam from the cameras pallet (eg select light 1 and shadow cam 1). Now if you move the light the camera should move
Opie2150 ( ) posted Fri, 30 October 2020 at 2:27 PM
I have a "Light 1" but only have a "Shadow cam light 4" I have a ground shadow if I select "ground shadows" or "ground + hardware shadows" I don't have any shadows if I only have "hardware shadows" selected The shading on the figure changes as I move "light 1" but the figure doesn't cast a shadow beyond the figure.
