Mon, Feb 10, 12:03 AM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Feb 03 7:20 pm)
Subject: First Poser Update 12.0.276 (Win) is Available for Download
tim ( ) posted Fri, 06 November 2020 at 4:17 PM · edited Mon, 10 February 2025 at 12:01 AM
Site Admin
https://www.posersoftware.com/downloads
On behalf of the Poser Dev Team, Enjoy!
Y-Phil ( ) posted Fri, 06 November 2020 at 5:21 PM
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
ghostship2 ( ) posted Fri, 06 November 2020 at 10:17 PM
Thanks!
TheAnimaGemini ( ) posted Fri, 06 November 2020 at 10:50 PM
Thank you.
― Marcus Aurelius,
blackbonner ( ) posted Fri, 06 November 2020 at 11:23 PM
Seem to be more stable than the version before. Installed the newest version yesterday evening, no crash so far. I will load my Runtimes today and load some older scenarios. In the material room i found the glossy shader is working now, the other specular shaders not.
ChromeStar ( ) posted Sat, 07 November 2020 at 12:02 AM · edited Sat, 07 November 2020 at 12:03 AM
Awesome. The release notes are appreciated too. The previous beta was 12.0.261, so the updates are as below. Especially note the Known Issues, that makes clear that the intention is that superfly renders should look the same as in 11 (if you don't use any of the new stuff). The notes for .272 maybe address the weirdness with the background, too.
Poser 12.0.276 - 2020-11-06
  • Shader XML issues triggered by EZDome fixed (#675)
  • Vector type input is not a menu choice but a number (#598)
Known Issues (high priority for next update):
  • Superfly renders can vary from Poser 11 due to Cycles 2 shader implementations
  • Raytrace Preview function not working consistently
Poser 12.0.274 - 2020-11-05
  • Queue Manager remote rendering network comms fixes #672
  • Queue Manager setting added for verbose logging of network comms
Poser 12.0.272 - 2020-11-05
  • WxPython fix, poser.WxApp() no longer crashes. #665
  • Cycles Surface image texture now loads in correct projection from Poser 11 to Poser 12. #633, #582
  • EnvironmentMap node uses equirectangular as default. flipping values now fixed #618, #561
  • Mapping node no longer has duplicate fields. #615
  • SuperFly Raytrace Preview has no longer Depth of Field turned on. #663, #607 (edited)
Rhia474 ( ) posted Sat, 07 November 2020 at 9:44 AM
This is very promising. Thank you.
Notsrella ( ) posted Sat, 07 November 2020 at 11:41 AM
Thanks for all your efforts!
