Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
I'm hopeful that we may see this as a native and new feature in Poser 12, but I may be disappointed.
Yes, there was a $10 'Exploder' script from PhilC, which circa 2006 was updated to Poser Pro 2014 as a commercial item on the Renderosity Store. But this is no longer sold and seemingly did not make it to Poser 11.
The older free version of Exploder is on the Ockham's Bungalow page (the zip download is currently broken there, but is available via the WayBack Machine), though that is from 2004. It's also on Renderosity Freestuff listed as "Exploder (Python"), though again in the 2004 version. I'd assume you need a copy of Poser Pro 2010 or lower to run it.
The best way I've found for shattering objects is to use Cell Fracture on the model of choice in Blender (there are tutorials so won't get into that part).
Once complreted, export all the pieces as a single object but set it to make objects as groups.
-Import it to Poser, first make sure the materials/textures are good, then open the Group Editor.
-Click Spawn Props.
-From there you can hide or delete the original from the scene.
If you really wanna go further you can add a choreographed object to animate (like a ball bursting through) to cause the pieces to react in certain ways. then hide it. I know I skipped a lot of details but this is basically what I've done.
[I'd show a gif but apparently they do not work on this forum.]
Edit: Here's an example
https://twitter.com/i/status/1148026404363264001
_____________________________
My most recent Poser animation:
Previs Dummies 2
Hello there!
If I wish to shatter a glass object (lets say a flask, falling on the floor) - what will be your method of doing so from within Poser?
I know there's an old python script (Ockham if I recall) called shatterize, but I haven't tested it yet. any ideas?
