Thu, Jan 30, 7:44 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Jan 26 3:18 pm)
Subject: Poser 12 and Hexagon scale different than before
722 ( ) posted Fri, 13 November 2020 at 12:47 PM · edited Thu, 30 January 2025 at 7:42 PM
Figuring out the new scaling help please.
ghostman ( ) posted Fri, 13 November 2020 at 4:43 PM
Yes something is clearly changed in this area. Will see if i can figure it out
"Dream like you'll live forever. Live like you'll die tomorrow."
Join PoserLounge Chat
tsoren ( ) posted Fri, 13 November 2020 at 6:37 PM
I just did a simple experiment. I exported the default Blender cube. It is simple, only the 8 necessary vertices. Inside Blender it is interpreted to be 2 units per side, a unit in Blender is 1 meter. Looking at the exported .obj file using a text editor, I can see the vertex data using 1 and -1 values. So this is consistent 1 to -1 is two units. The geometry described is two units per side, centered around 0,0,0. I import this obj into Poser. Now Poser interprets it as a cube, two units per side. A Poser unit is 8.6 feet or 2.6218 meters. A cube that is 2 units per side therefore shows up in Poser as 5.24256 meters per side. So what you can do is determine what a native Hexagon unit is in relation to feet or meters. Then you will know what scale factor to apply either at the Poser export or the Hexagon import. If you use a simple 8 vertices cube, import into Hexagon, use a measuring tool in Hexagon or view the size somehow, then you will know how a unit is represented in Hexagon and can compare that with Poser's unit to determine the scale factor.
Save the below text as a BlenderDefaultBox.obj file, and it can be your test file.
# www.blender.org
o Cube
v 1.000000 1.000000 -1.000000
v 1.000000 -1.000000 -1.000000
v 1.000000 1.000000 1.000000
v 1.000000 -1.000000 1.000000
v -1.000000 1.000000 -1.000000
v -1.000000 -1.000000 -1.000000
v -1.000000 1.000000 1.000000
v -1.000000 -1.000000 1.000000
s off
f 1 5 7 3
f 4 3 7 8
f 8 7 5 6
f 6 2 4 8
f 2 1 3 4
f 6 5 1 2
tsoren ( ) posted Fri, 13 November 2020 at 11:03 PM · edited Fri, 13 November 2020 at 11:04 PM
If Hexagon is treating one unit in the .obj file as 1 cm, then these percentage values should work to convert on export and import from Poser. Poser to Hexagon, export % value 26212.8 Hexagon to Poser, import % value 0.381493011048
ghostman ( ) posted Sun, 15 November 2020 at 8:32 AM
those values aren't working at all.
Before it was as simple as Import at 500.000 and export at 0.002 to get it all in the right size.
ghostship2 ( ) posted Sun, 15 November 2020 at 9:17 AM
file a bug
ghostman ( ) posted Sun, 15 November 2020 at 9:21 AM
ghostship2 posted at 9:21AM Sun, 15 November 2020 - #4404705
file a bug
already on it. ;)
RAMWorks ( ) posted Sun, 22 November 2020 at 12:55 PM
Would be nice if the import and export options contained a drop down with various scale and setups for various software packages. Comes in handy for situations like this, even updated would be a no brainer for allot of us!
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
722 ( ) posted Wed, 25 November 2020 at 2:54 AM
Love that idea. RAMWolff posted at 2:54AM Wed, 25 November 2020 - #4405507
