Sat, Nov 9, 11:55 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: [UPDATE] for P12 Script Starter
Bastep ( ) posted Fri, 20 November 2020 at 12:40 PM · edited Fri, 08 November 2024 at 2:30 AM
Update for P12 Script Starter. Unfortunately a small error has occurred, so a file has to be exchanged. The updated version can be found here: Updated P12 Script Starter Users who have already installed the addon only need to replace the file Script Starter.py in the directory \Runtime\Python\poserScripts\Bastep\Script Starter.
Greetings
Miss B ( ) posted Fri, 20 November 2020 at 9:04 PM · edited Fri, 20 November 2020 at 9:06 PM
Talk about timing. I just downloaded it about 2:00pm EST this afternoon. Did you update it later in the day today? Should I redownload it?
Never mind, I just saw what time you posted this, and I downloaded it afterwards, so I believe I'm good. 🙂
_______________
Butterfly Dezignz
