Sun, Nov 24, 6:57 AM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2024 Oct 22 2:54 pm)
Subject: Poser Update 12.0.306 (Win) is Available for Download
tim ( ) posted Wed, 25 November 2020 at 12:14 PM ยท edited Wed, 13 November 2024 at 9:55 PM
Site Admin
https://www.posersoftware.com/downloads
Relevant release notes below.
Poser 12.0.306 - 2020-11-25
  • Edit menu Copy Picture no longer produces a dark image when pasting into an image editor. #607, #570
  • Fixed issue with extra render files left behind even when PostFX or Auxiliary Layers not specified. #728
Known Issues:
  • sporatic reports of content related render crashes, currently being investigated
  • PoserPython scripting issue reported with equality operator on objects
Poser 12.0.300 - 2020-11-20
  • Rendering with Separate Process On and with Render in Background no longer causes crash. #703
  • SuperFly render settings option to Apply Post effects to Render now has an Open PostFX button that allows you to set the adjustments before rendering. #439
  • SuperFly render settings now allow user to select multiple GPUs for hardware render. #661, #573
  • Local and remote queue rendering now allows GPU for SuperFly renders. #483, #350
  • Setting the camera shutter open/close values gives improved results for SuperFly 3D motion blur. Not currently setup for Queue rendering. #707, #224
  • File locator dialog now launches when opening scenes that have missing image maps or environment textures. A warning also prompts when textures exceeds 4096 pixels. #671
  • Cycles Mix Blend option nodes improved consistency between Poser 11 & 12. #686
  • The new SuperFly auxiliary layer options are no longer linked to the FireFly auxiliary layer options. (#644)
  • Windows installer backup preferences option updated for clarity, now reads "Backup and replace preference files" #702
  • Blinn, EZ Blinn node hooked up to the Poser Surface root again renders correctly in SuperFly. #678
Y-Phil ( ) posted Wed, 25 November 2020 at 4:20 PM
Great! Thank you ๐Ÿ˜„
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐Ÿ‘ฟย Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
๐Ÿ‘ฟย Nas 10TB
๐Ÿ‘ฟย Poser 13 and soon 14ย โค๏ธ
lsauvage ( ) posted Thu, 26 November 2020 at 1:20 AM
Nice ! Now rendering wil be faster than ever.? i will test it this week-end
Mec4D ( ) posted Thu, 26 November 2020 at 12:02 PM
Very fast rendering with multiple GPUs almost 10 times faster than with CPU on my system
_________________________________________________________
"Surrender to what it is -ย Let go of what was -ย Have faith in what will be "
lsauvage ( ) posted Thu, 26 November 2020 at 12:48 PM
yes, i didnt resist an tried. Multiples GPU is really nice. So much faster than 11 version. I didnt succed rendering with gpu in queue, i must check it again
