Poser 12 F.A.Q (Last Updated: 2024 Oct 22 2:54 pm)
Rhia474 posted at 4:24AM Tue, 15 December 2020 - #4407553
It is present every time I use the Background node specifically.
Same here. I haven't attempted in other materials yet, though.
Feel free to call me Ohki!
I am not sure to understand the problem, I mean: using P12, I've created a 16384x8192 jpg picture, with a vic4 character and one spot. Then, I have been able to use it as a background picture for P11 and P12. Could this be related to the quantity of RAM available on the graphic card?
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Oops sorry. Indeed, it looks like only standard Jpg pictures are supported bigger than 4096px, neither HDR pictures nor tonemapped Jpgs.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
If you plugged in an hdr file like Rhia474 shows above, it worked before, so it's not the file format. It occurs when you plug in a Cycles environmental texture into the background node (using the mapping and texture coordinate nodes as above). I haven't tried other setups, so this may not be the only issue. Point is, the latest update broke this. It worked before.
Yes, the envsphere from bagginsbill works. However. It is sort of embarrassing that their own native background node was fine before Nov 25 and is now restrictive enough that it requires messing with 4k hdri maps which are not that big. Why? Why break what worked? Can this restriction be removed please?
If nobody has, log it with support so there’s a better chance of it getting fixed
I personally don’t think I should since I don’t own P12 yet or I would have.
Got this error when plugging an environment texture into the background in the latest Poser 12 build. This was not an issue with the previous upgrade. It occurred in a scene I was working on before the upgrade and in a new scene, no changes, where I just changed the background nodes to check this issue. The error message pops up a few times, and then Poser freezes and needs to be killed via task manager.
Anyone else also have this problem?
