Poser 12 F.A.Q (Last Updated: 2024 Oct 22 2:54 pm)
hborre posted at 12:31PM Wed, 16 December 2020 - #4407739
So far, all these renders look exceptional. @TheAnimaGemini, thank you for the shader recipe, it looks amazing. I'll pop it into my custom cycles Library folder.
Welcome. You can tweak it on the Layer Weight node. The blend you can change in another value.
― Marcus Aurelius,
Great looking renders @ghostship2 and @TheAnimaGemini, and thanks from me too for that Emissive Shader. I'm definitely going to be playing with it.
_______________
Miss B posted at 5:08AM Thu, 17 December 2020 - #4407750
@Miss B Thanks. Here I have another interesting shader variation for émissive. Make the actual emissive prop invisible In this picture La Femme has a gigantic Sphere over her head. But when you just want the light and effect, here is the shader to make it invisible. I think great for Sci Fi or Cyberpunk renders. I use here the big emission sphere and as rim light I use HDRI , dim it down to dark grey and block it with just a background prop. I actually love to use HDRI for Rim lights. Gives nice effect.
― Marcus Aurelius,
TheAnimaGemini posted at 7:34AM Thu, 17 December 2020 - #4407786
Awesome. thanks
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Y-Phil posted at 11:08AM Thu, 17 December 2020 - #4407793
Awesome. thanks
Welcome. They are not perfect , but should do the job when you need some nice effects. For the HDRI rim light I use to plug in the texture coordinate in the reflection slot. This way I have only the reflection from the HDRI.
― Marcus Aurelius,
That's definitely an interesting way to set up a Rim light. Thanks from me as well.
_______________
TheAnimaGemini posted at 5:15PM Thu, 17 December 2020 - #4407732
In fact, your idea of an emissive shader, applied to the construct's background, creates a kind of Global Illumination. I've used it here, with Bagginsbill's Fog Capsule to create this atmosphere...
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Miss B posted at 8:43PM Thu, 17 December 2020 - #4407816
I rarely use HDRI as full light. I think it gives me not enough control over my light and shadows in the scene. I use HDRI mostly as a small fill, or rim light. Blend it out with a backdrop or props , drop the strength and set up lights individually. It works great in Blender, now I have to convert this method seamless in Poser. Still some small problems to solve, because Poser behave different, but almost there. :)
― Marcus Aurelius,
@ Y-Phil: Try adding a Blackbody node to the emission color connector and you can create global illumination to the exact color temperature of your environment. The shader below is my setup for having different Kevin degree values for different lighting conditions. Combining the TheAnimaGemini node arrangement, I can control color temperature and modulate the brightness.
I would stay away from color temperatures around 1500 degrees, that is the color of candlelight and it does not render well as global illumination.
@TheAnimaGemini tricks for the noise reduction: 1) large renders (i normally do 1920x1080). 2) only use it on the most stubborn renders and only after LOTS of samples. This image is 70 samples (4900 samples). It worked well on this but I've had the same issues as you with it blurring things too much on other renders. Another version with a different camera position, sub d on the bottles and higher exposure setting (more than 3 on the FX setting)
It seems to use some algorithm to try to estimate what's a feature and what's noise, and adjust the scale of noise removal accordingly. The more noise, the larger the scale of the smoothing. Here's a render I did at super low quality (just 3 samples!) and way too much light. I hadn't meant to leave the denoise on, it was just a quick lighting test. But the effect is pretty interesting even if it isn't what I meant at all.... turned it into something like brushstrokes.
Since I'm posting that, here's something that came out how I intended, from the same set of models (by Nightshift3d):
ghostship2 posted at 10:39PM Sun, 20 December 2020 - #4407907
hborre posted at 3:40PM Fri, 18 December 2020 - #4407899
Cognac. My wife translated it.
I thought it was white wine so I colored it pale yellow. lol
Well Cognac is some kind of vine too LOL
― Marcus Aurelius,
@ghostship2 There are four point lights down in the pit, plus a sheet of lava which is an emissive surface (physicalsurface root node, emission strength set to 1 with a fairly bright image map attached). The eyes are emissive surfaces too. Then a pair of point lights out past the doorway (i.e. not in this room), you can see one through the portcullis and the other is behind the camera.
Diffuse bounces was only set to 1. Since you asked about it, I tried a render with it raised to 4. As you might expect, that fills in the shadows quite a bit. Light bounces around more, and gets to more of those places. In this case I like it better with the lower value. The higher value did reduce the graininess, probably just because there is more light.
ChromeStar posted at 9:09PM Tue, 22 December 2020 - #4408148
I'd set diffuse bounces to 6, make sure the point lights were on inverse square and then adjust the exposure down (post FX) after render to your liking. As is it looks like a video game render. No trying to offend just here to help!
Hmm, never played with the attenuation setting on the lights before. They were on constant which seems to be the default. I take it the inverse square setting causes the light to fall off more with distance? So instead of the corners being dark due to light not having enough bounces to get there, they are dark because the light has fallen off with path length. I will have to remember that.
I did have to triple the intensity of all the lights (which makes sense), could probably have gone even higher but that at least let me crank up the exposure without adding too much noise. Also doubled the number of samples. But I see what you mean. The eyes are particularly improved (do emissive materials in superfly attenuate at the inverse square rate too?). I tried the denoise again, and while it completely removes all the noise, even at 50 samples here it seems like it is erasing too much detail. Can't complain too much about the number of samples though, it was still only a five minute render with optix.
Yes, you can attenuate emissive mesh lighting by adding a LightFalloff node to the strength connector of the Emission node as illustrated below:
Use the Quadratic connector, it attenuates the light, and control the intensity with the strength value on that node. That Blackbody node controls the light temperature in degrees Kevin, you can simulate different types of lights like candlelight to bright midday lighting. Depending on the temperature range, you can imitate LED, incandescence, halogen, etc.
That's what it appears to do. I ran a whole series of renders changing the smooth value combined with the Quadratic connector and found that you can modulate the light emission intensity without losing the source mesh light intensity. This is particularly helpful if you are placing an image on a prop or plane and want to control the emission without losing details on the image.
you obviously bought them for reference material. If a writer can lookup 50 ways to dispose of a body and no one bats an eye, than an artist can buy fashion magazines
ghostship2 posted at 10:20AM Tue, 29 December 2020 - #4408837
Wow... splendid picture
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Santa was good to me this year and I found Poser 12 under the tree.(okay, not literally) Here's my first render with it
Was trying out the new principled hair shader. it works decent, but the thickness of the strands mattered. I couldn't go as low as I usually like.
It's not a complicated setup. I just played around with some values until I got something decent. I don't know about any tangent issue.
I finally got the settings I was looking for: the base layer is using the PrincipledBSDF node, without specular, but with a mix of transparency and a working anisotropy in a second layer. Scene lit with an HDRi on the background node + a big area light.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
WOW, Great images here folks!
WildManeHair. I beta tested that eon's ago. I used to have it but I can't find it any more, since I didn't have to pay for it, it was probably on some hard drive that crashed and burned. Nice to see Apollo again!
---Wolff On The Prowl---
Another portrait with my light experiments LF Character Tempesta Hair Bisquit
― Marcus Aurelius,
