Thu, Nov 28, 3:22 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Nov 17 7:07 pm)
banner
Subject: Changing "hidden" hotkeys?
Vaskania ( ) posted Tue, 22 December 2020 at 4:00 PM · edited Thu, 28 November 2024 at 1:20 PM
Since the last time I used poser, I've become more accustomed to using a more standard hotkey setup (q/w/e/r for select/move/rotate/scale and alt+left/middle/right for rotate/pan/zoom). The default move hotkeys (ctrl+spacebar+drag, spacebar+drag, etc) seem locked away under hidden, while the select/move/rotate/scale appear in both the hidden and the hotkey editor in preferences.
Is there a file somewhere I can get access to change the stuff in the "hidden" hotkeys? Also, while I'm at it, why are some hotkeys bound to uppercase letters, while others are lowercase of the same letter? How in the world?
-----sig-----
Daz, Blender, Affinity, Substance, Unity, Python, C#
structure ( ) posted Tue, 22 December 2020 at 4:31 PM
Forum Coordinator
Locked Out
Vaskania ( ) posted Tue, 22 December 2020 at 6:32 PM · edited Tue, 22 December 2020 at 6:37 PM
Ok, I've realized that the "mode" shortcuts in the hidden shortcuts are named something different in the key preferences, ie Pose Mode (hidden) -> Select Actor (key prefs).
What I can't find is where to remap XY Translate, Z Translate, Pivot, and Axis Constraint. Also, if there's a way to reverse zoom natively. Right now I use Netherworks' Camera Panel Plus to do it.
-----sig-----
structure ( ) posted Wed, 23 December 2020 at 7:43 AM
Forum Coordinator
It may only be possible with the use of a script
Locked Out
Vaskania ( ) posted Wed, 23 December 2020 at 5:17 PM
Alright, thanks. I'll take a dive into poser's python reference and see what I can find.
-----sig-----
