Tue, Feb 11, 9:47 AM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Feb 03 7:20 pm)
Subject: Morphing Tool will not open.
VirtualCity ( ) posted Sat, 23 January 2021 at 1:59 AM · edited Tue, 04 February 2025 at 12:45 PM
Why is it that the Poser 12 Morphing Tool doesn't connect or is unusable for prop blending? Sometimes it does open and I'm able to blend props, character grids or blend hair but most of the time the window is greyed out as shown in the picture. I'll sometimes then have to revert to Poser Pro 14 to use the 14's Morphing Tool on the same props, characters or hair just to get the visually correct dynamic to work and then reopen the same scene in Poser 12 to continue working. And even then the Poser 12 Morphing Tool still won't open. Any ideas on fixing the glitch? Motphing Tool.PNG
bwldrd ( ) posted Sat, 23 January 2021 at 2:53 AM
Online Now!
Right at the very top under Edit, you have to either select a morph to edit, or make a new one. Then the tools should be available.
Consider me insane if you wish, but is your reality any better?
VirtualCity ( ) posted Sat, 23 January 2021 at 6:23 AM · edited Sat, 23 January 2021 at 6:24 AM
That's weird! I usually just click on the area, prop or item I wish to morph, select the Morphing Tool and go. Now I have to select the area, open up the Morphing Tool, hit the 'Select or Create a Morph' tab, select 'New', give it a title like Hair or Dress depending upon the prop, character, hair to Morph and then... I can work. Whatever. The new Wire diagram system in the Material's Tab was new to learn as well. Thanks for the help!
