Sun, Dec 22, 7:56 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Dec 17 11:57 am)
banner
Subject: How do I set up a makeup MASK in Poser 11 for La'Femme
RAMWorks ( ) posted Sat, 23 January 2021 at 1:56 PM · edited Sun, 22 December 2024 at 7:28 PM
So I think I have myself wrapped around the axil here.
I was under the impression that using the Layer option would do the trick but I guess I was wrong. I have created TWO masks that I THINK go into the Transparency plugin(s) and then load the make up PNG layer into the Diffuse, correct? I'm getting nothing like I expect, instead the black of the mask is rendering to the edge of the face. I've tried it with and without the mask! I've tried the mask inverted to see if it was my brain messing up on me. Nothing is working!
Please help!
Thanks so much Richard
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
RedPhantom ( ) posted Sat, 23 January 2021 at 5:48 PM
Site Admin
This is how I set up masks for makeup or other multi-texture shaders. I don't use the layers, because I forget about them and I'm used to using masks to combine them on one layer. I collapsed the nodes because they were actually for glowing tattoos so they wouldn't make sense, but the idea is the same. Your mask needs to be black and white. Where the black is, goes in the first closure and the white goes in the bottom.
I'll try to come up with a sample for layers and post them. Remember, layers don't work on firefly.
RAMWorks ( ) posted Sat, 23 January 2021 at 6:02 PM
OK, when and if I'm ready for Cycles I'll save this set up. For now this was for Firefly and Superfly PoserSurface and PhysicalSurface.
My Store is HERE
RedPhantom ( ) posted Sat, 23 January 2021 at 6:11 PM
Site Admin
Here's how I set up the top layer. the bottom was just a simple diffuse. It worked with either the poser surface node to the cycles node set up as shown. I didn't try the other one. The transparency is the black on the mask. Also, make sure you change the color chip on the transparency node to white or it won't work.
RedPhantom ( ) posted Sun, 24 January 2021 at 6:37 AM
Site Admin
for firefly, you can use masks, but it can be a little more complicated, depending on your shader. You would need to use a blender node for each of the sockets you use that have a different value for the 2 portions of the shader. Set the blending to 1 and plug your map into it.
For the physical surface and layers, set the transparency to 1 and plug your mask in it. White will be where the top layer shows.
And just for the fun of it, I made a quick shader with the physical surface node in the top layer and tried both the poser surface and then the cycles root nodes in the bottom and they worked too. so you can miss and match. But as I said this only works with the superfly render engine.
RAMWorks ( ) posted Sun, 24 January 2021 at 10:52 AM
Thank you so much RedPhantom! Very much appreciated!
My Store is HERE
3dcheapskate ( ) posted Tue, 26 January 2021 at 7:08 AM · edited Tue, 26 January 2021 at 7:14 AM
If you want a ready-made Firefly shader for three layers with lots of Blender nodes have a look at my Poser-Shader-For-S.E.Asian-Shields ShareCG freebie from 8 years ago. It included a generic three layer shader.
But remember to put on your peril-sensitive sunglasses before looking at the shader network...
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
3dcheapskate ( ) posted Tue, 26 January 2021 at 7:12 AM
Well I never, it appears that I also included a generic two-layer shader in that !
RAMWorks ( ) posted Tue, 26 January 2021 at 10:29 AM
BRAIN EXPLODES lol OMG!
My Store is HERE
