Fri, Sep 20, 10:44 AM CDT
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Poser 12 Python API PDF
redspark ( ) posted Sun, 31 January 2021 at 4:33 PM · edited Thu, 15 August 2024 at 1:21 AM
I just installed my Poser 12 on my M1 Macbook Air. Everything is going smoothly but I noticed that there isn't an option to open the Python API PDF. And that PDF is no longer in the application folder. Where can I find a new copy? Thanks.
R
structure ( ) posted Sun, 31 January 2021 at 4:55 PM
Forum Coordinator
did you install the support files?
Locked Out
redspark ( ) posted Sun, 31 January 2021 at 5:44 PM
There isn't any installer for that in 12. There is in 11 but not 12. Just the Queue Manager and the main Poser installer. I used the Main Poser installer. Was there something I missed? Thanks.
structure ( ) posted Sun, 31 January 2021 at 9:57 PM
Forum Coordinator
FVerbaas ( ) posted Mon, 01 February 2021 at 11:59 AM
Forum Coordinator
The Poser 12 Python manual is still 'in the works'. I have the impression they want to do a proper update rather than a cosmetic rewrap, which indeed would not add much. There have not been big changes in the API since Poser11, so you can use the Poser11 manual, with all its flaws.
