Mon, Nov 25, 6:32 AM CST
Subject: Is Hivewire3D Down?
EClark1894 ( ) posted Thu, 04 February 2021 at 4:56 AM · edited Wed, 20 November 2024 at 6:15 AM
Is Hivewire3D down. I can't get into their forum. Which is really weird considering, I got in yesterday morning, but ever since I've been told that I'm unauthorized and need to sign in. That's never happened before. ...EVER.
HartyBart ( ) posted Thu, 04 February 2021 at 6:10 AM
The Store has recently closed, and most vendors are slowly moving over to Renderosity. The Forum is separate and continues as usual. The Forum is accessible for me, and the User-name shows up as logged in.
RedPhantom ( ) posted Thu, 04 February 2021 at 6:15 AM
Site Admin
It looks like it from here, and https://downforeveryoneorjustme.com/ says it is too.
Rhia474 ( ) posted Thu, 04 February 2021 at 7:17 AM
Try direct forum url at: https://community-dot-hivewire3d-dot-com/
Works at the moment.
rokket ( ) posted Thu, 04 February 2021 at 7:20 AM
I tried to log in. Nothing happened.
EClark1894 ( ) posted Thu, 04 February 2021 at 7:48 AM · edited Thu, 04 February 2021 at 7:50 AM
Rhia474 posted at 7:48AM Thu, 04 February 2021 - #4411873
Not for me.
stallion ( ) posted Thu, 04 February 2021 at 8:12 AM · edited Thu, 04 February 2021 at 8:13 AM
you have to replace the word "-dot-" with "." in the url I was able to access the site
You might as well PAY attention, because you can't afford FREE speech
Rhia474 ( ) posted Thu, 04 February 2021 at 8:48 AM
Sorry, it's a habit of mine not to post direct links on this forum.
3WCreations ( ) posted Thu, 04 February 2021 at 9:44 AM
I was just there, worked for me.
______________________________________________________________
Everything important in life I've learned from somebody else's forum signature.
EClark1894 ( ) posted Thu, 04 February 2021 at 12:07 PM
Okay, changing the dots to "." worked for me. Thanks.
Miss B ( ) posted Thu, 04 February 2021 at 3:32 PM
I think there was an issue very early this morning, because I had an issue just before logging off at 1:30am EST. Not sure what the issue is, but I know it was mentioned on the forum that it was assumed the store pages would still be available after Jan. 31st, there just wouldn't be any downloading available, and that's not what happened.
I'm assuming they were trying to fix it so the store pages were still available for those CAs who were moving their products here would be able to access the product descriptions on their products to updating for Renderosity's store.
That said, I haven't had any issues with the forum, but the store page is not available.
_______________
Butterfly Dezignz
HartyBart ( ) posted Thu, 04 February 2021 at 3:41 PM
Still working for me. Most likely a DNS problem. When this happens try:
  1. Right-click Internet icon in Windows System Tray, Open 'Network and Sharing'.
  2. 'Change Adapter Settings', right-click 'Wi-fi' icon, select 'Properties'.
  3. Scroll down to the bottom of the list to 'TCP/IPv4', click 'Properties'.
  4. At 'Use the following DNS server', type in 9.9.9.9 and 8.8.8.8 and click OK. Exit.
You just told your Web browser to bypass your ISP DNS and to use Google's DNS server, and also to fallback to another reliable one (8.8.8.8) if that fails.
EClark1894 ( ) posted Thu, 04 February 2021 at 6:23 PM
I just did what Rhia suggested, then bookmarked it. Been working ever since.
jartz ( ) posted Thu, 04 February 2021 at 7:18 PM
It works for me. As of 8:18 pm, EST
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
Miss B ( ) posted Fri, 05 February 2021 at 12:30 AM
Rhia474 posted at 12:27AM Fri, 05 February 2021 - #4411884
A habit of mine as well, though I would usually type it as https://community (dot) hivewire3d (dot) com/
I think folks would realize what I meant, rather than thinking the -dot- was actually part of the URL, as that's what I thought when I read your post.
_______________
Butterfly Dezignz
Ken1171_Designs ( ) posted Sun, 07 March 2021 at 2:47 PM
The bottom line was that links from the main page were no longer working. We have to manually type in the forums URL address and bookmark it instead. If we try from the main page, it will require the store login and password, which no longer exist. The store and forums used different logins, and that's why people couldn't get in. Just use the URL address MissB has suggested, and you should be good to go. :)
My Store at Renderosity
My Store at PoserSoftware
Characters, Body Sculpts, Morph Corrections, Outfits, Python Scripts, Universal Heads, and Videogames!
