Thu, Jan 23, 6:23 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Jan 20 8:00 pm)
Subject: Specularity bug - Tracked down
AcePyx ( ) posted Thu, 11 February 2021 at 2:01 AM · edited Thu, 23 January 2025 at 6:21 PM
Further to my earlier post, I have now managed to identify what is causing the specularity bug. RECAP: A figure with a single distant light, animated in a 360 degree circle, and each frame has wildly differing specularity. The problem is the shadow blur radius. If it is anything but zero, regardless of if you are are using depth mapped or ray traced shadows, creates this instability (see frames below). There was a shadow blur bug of another kind, which was supposedly fixed in version 12.0.396, but this is a new bug
WORKAROUND A distant spot does not have the specularity bug
Below - two consecutive frames - light not animated
bagginsbill ( ) posted Thu, 11 February 2021 at 5:58 AM
Yikes that is broken.
hborre ( ) posted Thu, 11 February 2021 at 8:57 AM
Report it and give them as much info and examples as possible. Attach your findings.
ChromeStar ( ) posted Thu, 11 February 2021 at 11:02 AM
Huh. I noticed the shadow blur turning on and off randomly from frame to frame before, but I assumed it was fixed now.
ghostship2 ( ) posted Thu, 11 February 2021 at 12:15 PM
Maybe this is the same problem as the infinite lights sometimes not rendering and then the next render they work again.
ChromeStar ( ) posted Thu, 11 February 2021 at 5:13 PM
I was just going to mention that. I've had that happen a couple times recently.
hornet3d ( ) posted Fri, 12 February 2021 at 6:56 AM
ghostship2 posted at 6:53AM Fri, 12 February 2021 - #4412565
OK that explains why I can get a very dark render on occasions but if stopped and the render stated again with no changes the render has the expected brightness. I guess it happens about one in twenty renders but I never manged to pin point as far as the infinite lights not rendering.
ghostship2 ( ) posted Fri, 12 February 2021 at 10:41 AM
@hornet3d yep, that'd be the bug.
AcePyx ( ) posted Sat, 13 February 2021 at 7:50 PM
hborre posted at 7:50PM Sat, 13 February 2021 - #4412541
Yes, already done thanks for the recommendation.
AcePyx ( ) posted Sat, 13 February 2021 at 7:51 PM
ChromeStar posted at 7:51PM Sat, 13 February 2021 - #4412548
Yes, they did claim that to be the case. I guess not with all lights.
AcePyx ( ) posted Sat, 13 February 2021 at 7:52 PM
bagginsbill posted at 7:51PM Sat, 13 February 2021 - #4412521
Yes quite so. Incidentally, really saddened that the SM forum has been deleted. So much of your wisdom lost :'(
AcePyx ( ) posted Sat, 13 February 2021 at 7:53 PM
ghostship2 posted at 7:52PM Sat, 13 February 2021 - #4412565
Ahhh, that one's not just me then? Interesting. It's been driving me crazy.
AcePyx ( ) posted Sat, 13 February 2021 at 7:55 PM
hornet3d posted at 7:53PM Sat, 13 February 2021 - #4412605
Yes, same here. I sometimes moved the camera and the lights worked again. I thought it was a problem with the way the program was handling bounce lighting or transparency as I only ever noticed it on indoors scenes. Good to hear your take on it.
