Wed, Jan 8, 4:38 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 08 11:18 am)
banner
Subject: Renders in Superfly are blank
RAMWorks ( ) posted Fri, 12 February 2021 at 9:58 AM · edited Sat, 04 January 2025 at 10:28 PM
I'm running Poser 11 for testing and setup purposes but now I'm getting NO good renders out of it. I can render fine in Firefly but Superfly is returning these lightening fast renders because it's not rendering ANYTHING! I've even uninstalled and reinstalled. Still the same results. No fancy settings either, just the Default which should work out of the box! What do I do?
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
ironsoul ( ) posted Fri, 12 February 2021 at 11:47 AM
Might be a coincidence but since midweek my Poser UI has become very sluggish and scenes that were rendering ok last weekend now are very slow and crash in progressive mode. Received Windows updates KB4601050 and KB4601319 on Wednesday. If you're using Windows would be interested to know if you also received these patches.
ironsoul ( ) posted Fri, 12 February 2021 at 1:52 PM
Update to above - I reinstalled the above updates (in between this process Microsoft kindly added another update), the Poser GUI performs ok now and a strange issue with metallic surfaces rendering black appears to have gone away too but the link between these problems and the patch are too circumstantial to say its was the cause. The problem with the progressive mode crash was down to me not setting a large enough bucket window (known bug).
ypvs ( ) posted Sun, 14 February 2021 at 7:45 AM
Re-installing/updating the graphics driver may also help (you didn't mention CPU/GPU render)
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Windows 7 64 bit, Avast AV, Comodo Firewall
Intel Q9550 Quad Core cpu,  16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
