Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Not sure why it won't run in Poser Pro 10 (best known as Poser Pro 2014), but there are a small number of Poser scripts that are flummoxed when they find they're set to run in Poser 11.2. I think it's due to the unfamiliar version-number(?). Anyway, to get those running need the free AVFix script at https://www.poserlounge.nl/PLWP/fix-for-scripts-in-poser-11-2/. This script run first, once, and then the recalcitrant scripts can run.
Here's how to have XA Toolbar and AVFix load together with Poser 11.2, and it works for me.
Copy poserStartup.py from C:|Program Files|Smith Micro|Poser 11|Runtime|Python|poserScripts and save one copy as a backup and another to the Desktop. poserStartup.py needs to be edited outside of C:|Program Files| as Windows won't allow editing there.
Open the Desktop copy of poserStartup.py with Notepad, and edit accordingly:
Note the required double back-slashes in the paths at the end of the script.
It may be to do with the load-order. I had no luck with one config method, re: the poserStartup.py and you'll see that both methods are deployed in this script (top and very bottom).
I don't know why. But all I can say is that AVFix + XZ Toolbar startup worked when one way was tried, but not the other.
Finally working after much grief. I edited my poserpystartup.py according to HartyBarts instructions. I also added the XL library to the ...startup.py. The XL library appeared slightly before the main poser window opened, but I still couldn't see the XA menu. I discovered the problem was that it was opening under my windows start menu bar that I have on the top of the screen. When I dragged my windows start menu bar to the side, it revealed the tiny XA icon on the very top of the screen. Thanks again for the help. Best Regards, Doug
Ah, yes it's forgotten about that 'tiny' aspect. Yes - now you mention it I seem to recall it starts very small, and then you have to tweak it to get it how you want it. It's a great tool though. You can also pin Python scripts to its icons.
Hi,
I'm having problems getting the XA Toolbar script to run in Poser Pro 2010 and Poser 11.2. I'm running Windows 10 Pro. The XL Content Library by the same vendor works fine. Any help would be appreciated.
https://www.renderosity.com/rr/mod/bcs/?ViewProduct=88877
