Tue, Feb 18, 7:37 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Subject: Body Parts Invisible after Leaving Setup Room
SergeantJack ( ) posted Tue, 16 February 2021 at 7:36 PM · edited Sun, 09 February 2025 at 9:22 AM
Hello, please help! I've got a figure that I've rigged in the setup tab, and when I leave the setup room and go back to the pose tab, every body part on the model except the top part of the hierarchy is invisible. When I go back into the setup tab, everything appears the way it should be, but invisible in the pose tab or the material tab.
I've checked the hierarchy editor, and all of the eye icons are turned on. I've also switched to the grouping tool to see if the invisible body parts have been assigned a material; they have the same material assigned as the main body part (which is visible), and furthermore, the entire figure is visible when the grouping tool is selected.
Please help! I'm completely stumped.
rokket ( ) posted Tue, 16 February 2021 at 10:19 PM
Did you by any chance put a check mark in the tab to hide the other groups while you were grouping and forget to uncheck it?
SergeantJack ( ) posted Wed, 17 February 2021 at 10:25 AM
Good thought, but no, I took a look at it and it's fine.
RobZhena ( ) posted Wed, 17 February 2021 at 12:24 PM
Is visible selected for each body part on the parameters tab? I’ve never had your issue surface, but I have had something rigged in the fitting room be invisible because the host was invisible.
