Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 9:14 am)
I do not really know about the triangle but the problem with the hair is that it is now located somewhere away from the head. Perhaps you can see it if you zoom out enough. This happened sometimes with ready made poses with me also. What I do is locate the hair from the menu under the image window and delete it. I then add the hair again and it comes in the right place. I am not that advanced in poser to offer a better explanation or solution but that seems to work OK.
The solution is to open the pose file in a CR2 or text editor and remove the references to the hair. I made those poses waaaaaaaaaaaaaaaaaaaay way back. Any I make now do not have the hair included for just this reason.
I've also found that the older one gets the problem of fly away hair diminishes :)
Yes, Phil. I found your older stuff, and was quite pleased because there is some really neat stuff there. I guess I will just use those Cheerleader poses with that character and see about trying to find others for Veronica or better yet, Vicky. I know about hair loss... I am 51, and have had a "receding hairline" for years...Then one day I used an extra mirror and found the back was going bald as well. The irony is that what is left of my hair is longer than ever before...
My only advice would be this. I was once offered a miracle hair restorer by a traveling salesman. He professed that his own flowing locks were the result of daily applications of his patented lotion. When he offered me the bottle I could see the palm of his outstretched hand. I immediatly knew he was a fake.
Can you tell why?
How to keep you hair on: 1) Add the character to the scene. 1a) Optional: add clothes. 2) Add Hair. 3) Select the Hair object and go to Object > Lock Actor 4) Select the character and pose away- the hair will always stay attached to the head, no matter how extreme the pose. It actually has nothing to do with the pose or the "parenting" of the object. When you apply a pose, the figure poses correctly, but since there is no "pose" for the hair, it stays in the same place- usually a few "feet" above or below the character. --John
VanishingPoint... Advanced 3D Modeling Solutions
