Wed, Feb 5, 3:19 AM CST
Renderosity Forums / Community Center
Welcome to the Community Center Forum
Community Center F.A.Q (Last Updated: 2025 Feb 04 12:04 pm)
Forum news, updates, events, etc. Please sitemail any notices or questions for the staff to the Forum Moderators.
Subject: NO IDEA WHAT I'M DOING AGAIN
Skiman ( ) posted Fri, 02 April 2021 at 5:51 PM · edited Thu, 30 January 2025 at 9:38 PM
If it's possible, can someone please explain a simple way, after I have downloaded content from Renderosity, where to unzip it and place it in Daz Studio? Like what folder? All of my folders in DAZ are empty with no content when I go to look, so obviously I am doing something majorly wrong. Thanks for any help! - Ski
hborre ( ) posted Fri, 02 April 2021 at 7:54 PM
It is obvious from your post that you are using DAZStudio and that the content you purchased is exclusively for the aforementioned application. Depending on which library folder DAZStudio has been configured to use, either My Library or My DAZ 3D Library, the contents of the zip file should be unzipped directly into either one of those. Those libraries should be linked to DS and that you know exactly which folder you unzipped your content. Two drawbacks can exist, if the vendor placed all the content folders into one primary folder then you will be nesting within the hierarchy of folders subsequently burying your content deep within the library where the program can't reach it. Or unzipping your content while DS is running, in which case you will need to refresh the Libraries.
antje ( ) posted Fri, 02 April 2021 at 8:50 PM
Hello,
Please take a look at this forum post. It explains how to install Renderosity products into DAZStudio folders:
https://www.renderosity.com/mod/forumpro/?thread_id=2916149
Antje :)
bbost ( ) posted Sat, 03 April 2021 at 9:11 AM
Here's what I do.
I create a folder on my D:/ drive and call it 1 I then create a second folder inside that folder and call it Content
So D:/1/Content that's the folder structure. Now unzip your zip files to D;/1/
Open DazStudio Under Edit/Preferences There is a content Tab, click the button and navigate to your new D:/1/Content
Everything in that folder is now available for use in DazStudio using the Content Library
