Sat, Feb 8, 10:28 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Hack: Cleam morphs covered by specific materials
adp001 ( ) posted Tue, 06 April 2021 at 4:36 AM · edited Sat, 08 February 2025 at 10:21 AM
For a special case I needed a script able to clean a morph if that morph touches a certain material. So I made one (not very well tested, but it seems to work):
from __future__ import division, print_function
try:
    import poser
except ImportError:
    from PoserLibs import POSER_FAKE as poser
import sys, wx
if sys.version_info.major > 2:
    # Python 3 (Poser 12 and above)
    basestring = str
    from importlib import reload
    map = lambda a, b: [a(_b) for _b in b]
    newIdRef = wx.NewIdRef
else:
    # Python 2 (Poser 11 and below)
    newIdRef = wx.NewId
def find_polys(polys, materialindexlist):
    """Find and return polygons with material index contained in materialindexlist."""
    poly_indices = list()
    for idx, poly in enumerate(polys): # type: (int, poser.PolygonType)
        if poly.MaterialIndex() in materialindexlist:
            poly_indices.append(idx)
    return poly_indices
def verts_from_polys(geom, polyindices):
    """Find and return vertices contained in polygons."""
    assert isinstance(geom, poser.GeomType)
    assert isinstance(polyindices, list)
    vertexindices = list()
    sets = geom.Sets()
    polys = geom.Polygons()
    for polyidx in polyindices:
        p = polys[polyidx]  # type: poser.PolygonType
        vertexindices.extend(sets[p.Start():p.Start()+p.NumVertices()])
    return vertexindices
def reset_morphs_in_material(figure, materiallist, morphlist=None):
    assert isinstance(figure, poser.FigureType)
    if isinstance(materiallist, basestring):
        materiallist = [materiallist, ]
    if isinstance(morphlist, basestring):
        morphlist = [morphlist, ]
    assert hasattr(materiallist, "__iter__")
    assert hasattr(morphlist, "__iter__")
    # Make a list of materialnames from figure.
    figure_matnames = [m.Name() for m in figure.Materials()]
    # Convert all materials in materiallist to index positions.
    # materiallist must contain strings or poser.Material objects.
    try:
        materiallist = [figure_matnames.index(m if isinstance(m, basestring) else m.Name())
                        for m in materiallist]
    except AttributeError:
        print("One or more materials is not string or ")
        return None
    except IndexError:
        print("One or more Materialnames could not be found.")
        return None
    for ac in [_ac for _ac in figure.Actors() if _ac.IsBodyPart()]:  # type: poser.ActorType
        if hasattr(ac, "Geometry"):
            geom = ac.Geometry()
            if not geom or geom.NumVertices() == 0:
                continue
            vertex_indices = verts_from_polys(geom, find_polys(geom.Polygons(), materiallist))
            if len(vertex_indices) != 0:
                for morph in [p for p in ac.Parameters() if p.IsMorphTarget()]:  # type: poser.ParmType
                    if morphlist is not None and morph not in morphlist:
                        continue
                    if morph.NumMorphTargetDeltas() != 0:
                        cnt = 0
                        for idx in range(geom.NumVertices()):
                            v = morph.MorphTargetDelta(idx)
                            if v[0] != 0 or v[1] != 0 or v[2] != 0:
                                if idx in vertex_indices:
                                    cnt += 1
                                    morph.SetMorphTargetDelta(idx, 0, 0, 0)
                        if cnt:
                            print(cnt, "morph vertices in", ac.Name(), ">", morph.Name())
Usage:
reset_morphs_in_material(figure, materiallist, morphlist)
"morphlist" is a list of morphnames or None. In case of None all morphs are used.
"materiallist" is a list of materialnames or poser.Materials(). Vertices contained in a morph and covered by one of the named materials are set to 0.
I used this to clean up morphs for hair with a lot of materialgroups. And for cloth to clean "buttons". It's faster and easier as using the morphbrush :)
an0malaus ( ) posted Thu, 08 April 2021 at 10:33 AM
Nice! :-)
My ShareCG Stuff
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
adp001 ( ) posted Thu, 08 April 2021 at 11:07 AM · edited Thu, 08 April 2021 at 11:08 AM
Thanks. But it wont work with a morphlist, because I forgot ".Name()" after "morph" :)
Here is a working version:
try:
    import poser
except ImportError:
import sys, wx
    basestring = str
else:
    newIdRef = wx.NewId
    return poly_indices
    sets = geom.Sets()
    try:
        return None
    except IndexError:
        return None
                continue
                    if morphlist is not None and morph.Name() not in morphlist:
                        continue
                        cnt = 0
                                    cnt += 1
                        if cnt:
