Sat, Feb 1, 3:12 AM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Jan 26 3:18 pm)
Subject: Missing Error information
RedPhantom ( ) posted Mon, 12 April 2021 at 6:38 PM · edited Sat, 01 February 2025 at 2:34 AM
Site Admin
With the latest update of Poser, when I run a render, and there are errors in the message log, I only get which nodes are problems, not which object or mat zone has the problem node
18:14:57 - SuperFly: Rendering memory: 1175 MB.
18:19:04 - SuperFly: Cannot connect output from node Blinn to input Value_2 on node Sub_6.
18:19:04 - SuperFly: Cannot connect output from node Reflect to input Value 1 on node Color_Pow_3.
18:19:04 - SuperFly: Cannot connect output from node Color_Add to input Value 1 on node Color_Pow.
18:19:06 - SuperFly: Start rendering on device AMD FX(tm)-8120 Eight-Core Processor.
18:25:40 - SuperFly: Rendering time: 394.32 seconds.
18:25:40 - SuperFly: Rendering memory: 1158 MB.
Does anyone else have this problem?
ChromeStar ( ) posted Mon, 12 April 2021 at 10:42 PM
I noticed that once, but when I looked back far enough, the object was listed -- an error had come up with it in a prior render so it was way back. Is that the case here? Maybe it doesn't want to repeat what object it was for every single error and it's being too careful to omit the redundancy?
If that's the case it would be better to flush that when you start a new render but it least it would explain what is going on.
seachnasaigh ( ) posted Tue, 13 April 2021 at 9:37 AM
@RedPhantom Just encountered that about ten minutes ago. My machine is Win7.
seachnasaigh ( ) posted Mon, 03 May 2021 at 11:49 PM
@RedPhantom Do you still see this in the 12.0.500 release?
